Old 08-26-2010, 10:55 AM   #1
CaMeRoN187
CaMeRoN187's Avatar
Drives: 2011 SW 1LT
Muffler Delete Question
I was wondering if a muffler delete will void my warranty, and what exactly should i tell the shop i want done to my car because i dont want them removing something i need.
thanks in advance for the responses.
CaMeRoN187 is offline   Reply With Quote
Old 08-26-2010, 10:59 AM   #2
LittleMT
user bann'd
LittleMT's Avatar
Drives: Chevy SS
yup, your muffler warranty goes right out the window!
Chantilly Lace, the 2011 Rockabilly Jukebox..ADM built..617rwhp, geared A6.
LittleMT is offline   Reply With Quote
Old 08-26-2010, 11:04 AM   #3
CaMeRoN187
CaMeRoN187's Avatar
Drives: 2011 SW 1LT
aww damn! looks like im not touching it then. thanks for the answer
Old 08-26-2010, 11:04 AM   #4
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Doesn't void any warranty besides, as previously mentioned, your mufflers being cut off...
The shop i used here had already done several and knew exactly what i wanted. Just tell them you want the mufflers cut out and straight pipe welded in. you can even re-use the stock tips as well.
If you want a cheap way to get sound...this is it. with the m6 there's some drone, but minimal in my opinion. You don't void anything that's still on the car... so i don't know why i you wouldn't want to.
Charged me 60 bucks cash here for the swap. Hope this helps!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 08-26-2010, 11:17 AM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
How does a muffler delete sound on a V6?
Old 08-26-2010, 11:28 AM   #6
ketel0ne
Drives: Used to have 2010 SGM
http://www.camaro5.com/forums/showthread.php?t=101593
ketel0ne is offline   Reply With Quote
Old 08-26-2010, 12:43 PM   #7
slick rick
SoCal Mayhem
slick rick's Avatar
Originally Posted by ketel0ne View Post
Thanks
Old 08-26-2010, 01:05 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Smart ass.
Old 08-26-2010, 01:10 PM   #9
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Smart ass.
lol... but you get answers like this which are
TommyTSquared is offline   Reply With Quote
Old 08-26-2010, 03:37 PM   #10
CaMeRoN187
CaMeRoN187's Avatar
Drives: 2011 SW 1LT
ima noob at this stuff :/
Old 08-26-2010, 04:28 PM   #11
caverman
caverman's Avatar
Drives: '69 SS Convertible
http://www.camaro5.com/forums/showthread.php?t=64964
Go through my thread and you'll understand more about what to do and what gets removed.
I would do the X-pipe as well but you don't have to. If you don't do the x-pipe then have them just remove the rear mufflers.
Build Journal
Old 08-26-2010, 08:27 PM   #12
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i think people didn't like the v6 in straight pipes
Old 08-26-2010, 10:22 PM   #13
PQ
Booooosted.
PQ's Avatar
Dude. For real. We are just playing. Your question is PERFECTLY valid. None of us knew this stuff till we asked.
Sorry if we made you feel awkward. It wasn't our intention.
Thing about just removing the mufflers on the V6 is .... well....it sounds just like you just removed the mufflers.
Old 08-26-2010, 10:48 PM   #14
KMPrenger
KMPrenger's Avatar
Don't do straights on the 6. You can get much much better results with a custom muffler setup for a couple hundred more bucks than the cost of labor for the straight mod. Save up and then go for it!
If money really isn't an issue, then you can spend even more and go for a Camaro designed axle-back or cat-back. (which may not necissarily sound any better than a thought out custom setup....its just easier!)
Its all in the research you do and what YOU like! Want some help....I've provided it. Go to the V6 section and check out the exhaust sticky I maintain there.
Good luck!
DIY: GFX Outlets add Wire Mesh and Paint, Muffler Delete Li0nel1234 Camaro DIY & HOW-TO instructions & discussions 25 01-07-2017 07:36 PM
Question...Is a muffler delete legal? PnCRedJwl2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 07-06-2010 08:47 PM
question about the muffler delete SamSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 11-27-2009 11:22 PM
DIY at home Muffler Delete for $20 CDBiker220 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 10-12-2009 06:32 PM
Considering a Muffler Delete, Straight Pipes or NOS in Ontario? Matster Canada 18 08-29-2009 03:41 PM
