Old 01-03-2011, 11:56 PM   #1
Forcer
Drives: 2018 Camaro SS
Question Ground effects to close to ground on some Camaros?
Hey guys!, i recently just got new 22" rims, now ive been consdering doing the lowering springs, i know it would look better, but im also considering getting the razzi ground effects, now since ive upgraded rims, ive went up another 2 inches higher, if i added the ground effects it would take away from how high up i look, but it may be safer so i dont rub, this is not just a "Show car" but i do love to "Show it" so i do want it to have less damage as possible...
My question is, Has anyone ever considered putting "Lexan" under their ground effect? so if it does rub, it just rubs the lexan? and you can replace it whenever? I thought this might be a neat concept for some to use, it adds alittle thickness, but the stuff is dang nice for protection...
Stuff is dang near unbreakable as well.
What are your guys Thoughts on ground effects vs lowering springs?
Forcer is offline   Reply With Quote
Old 01-04-2011, 12:07 AM   #2
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Having driven a slammed car before with a ground effects/body kit I would say "Lexan" isn't going to do much.
When you drive a car with those mods it really comes down to being really careful and aware of what your going over.
Also I just feel like lowering springs and 22s is a bad idea. I'd get coils personally. You probably should have just went with 20s with body kit and then you could do springs.
DarkneSS is offline   Reply With Quote
Old 01-04-2011, 12:33 AM   #3
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
I have 22s and lowering springs (eibach 1") and the stance is perfect. You just have to be careful going up and down driveways.
Old 01-04-2011, 07:58 AM   #4
Jayson9
Drives: 2SS
I got the Razzi V8 kit on mine, but with 20"s from the factory. If the height stays the same (22" with a 1-2" lower kit) you may be in good shape. My Razzi does not curb like my stock '06 CSRT8 front end does. That Hemi chin spoiler front end will drag on anything. But the Razzi mounts pretty square to the original front end, and seems to keep enough height to clear my upward sloped drive way. Haven't went over them, but would avoid speed bumps all the same.
Jayson9 is offline   Reply With Quote
Old 01-04-2011, 08:35 AM   #5
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2019 F150 RCSB Abyss FX4
How did you raise your car 2 inches higher? Do your tires not have less sidewall on them??
<info below provided by Nine Ball>
Factory 2010 Camaro SS tires and wheels
Front 245/45-20 = 28.7" tall, 8.0 wheel
Rear 275/40-20 = 28.7" tall, 9.0 wheel
Recommended 18" Tires for 2010 Camaro
245/55-18 = 28.6" tall, 8.0-8.5 wheel <-- Factory tire size for 18s
255/55-18 = 29.0" tall, 8.0-8.5 wheel
265/50-18 = 28.4" tall, 8.5-9.0 wheel
275/50-18 = 28.8" tall, 9.0-9.5 wheel
285/45-18 = 28.1" tall, 9.5-10.0 wheel
295/45-18 = 28.5" tall, 10.0-10.5 wheel
305/45-18 = 28.8" tall, 10.0-11.0 wheel
315/45-18 = 29.2" tall, 10.5-11.0 wheel
Recommended 19" Tires for 2010 Camaro
245/50-19 = 28.7" tall, 8.0-8.5 wheel <--Factory tire size for 19s
255/50-19 = 29.0" tall, 8.0-8.5 wheel
265/45-19 = 28.4" tall, 8.5-9.0 wheel
275/45-19 = 28.7" tall, 9.0-9.5 wheel
285/45-19 = 29.1" tall, 9.5-10.0 wheel
295/40-19 = 28.3" tall, 10.0-10.5 wheel
305/40-19 = 28.6" tall, 10.0-10.5 wheel
315/40-19 = 29.0" tall, 10.5-11.0 wheel
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
http://www.camaro5.com/forums/showpo...70&postcount=1
<info below provided by Camaro5 WIKI>
Jay_LHD3 is offline   Reply With Quote
Factory Ground Effects Vs No Ground Effects SOPMOD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 11-27-2010 09:51 AM
Ground effects before or after your buy your Camaro? LED Crazy 5th Gen Camaro SS LS LT General Discussions 12 08-16-2010 11:24 AM
How to take off front bumber with ground effects? Chad's ZL1 Camaro DIY & HOW-TO instructions & discussions 4 08-03-2010 07:57 PM
Gm ground effects kit ~Stacy~ Cosmetics and Lighting Modification Discussions 12 04-13-2010 02:09 PM
No more ground effects on 2010 Camaro j0hnny007 5th Gen Camaro SS LS LT General Discussions 26 02-28-2010 12:58 PM
