Old 02-22-2011, 08:17 AM   #1
5thGenCamaroKid
No fat chix, car scrapes.
Drives: 2014 GMC Sierra 1500
Choosing heads - help.
I'm not really sure where to start when trying to choose a set of heads to put on the LS3 and I'm hoping to garner some information from the forum members at large to help me understand and digest the numbers better.
Also, choosing a cam to match the flow of the heads - how do we go about this?
Thanks in advance for your expertise!
5thGenCamaroKid is offline   Reply With Quote
Old 02-22-2011, 08:26 AM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
I have no idea myself, but what are your power goals?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 02-22-2011, 08:41 AM   #3
5thGenCamaroKid
For now, in the high 400s to low 500s (if possible) RWHP with a substanstial amount of torque in the lower RPM range to get moving.
Old 02-22-2011, 08:43 AM   #4
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
If you don't mind waiting a little bit get with texas speed they are working on something that sounds fantastic. I hear them say it would be a few more weeks till they got them done but I think their products are great as well as their customer service. They are worth waiting for.
If you give them a call they will give you advice and help in any way they can.
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 02-22-2011, 01:08 PM   #5
5thGenCamaroKid
Noted - thanks.
Question still remains about what do the numbers mean when a vendor advertises heads at specific lift numbers? How do these affect which heads would be good as well as cam selection?
Old 02-22-2011, 01:35 PM   #6
tvwilkes
tvwilkes's Avatar
Drives: 2010 Camaro 2SS
You can have your factory casting ported. Call TSP and talk with them about heads & cam upgrades.
tvwilkes is offline   Reply With Quote
Old 02-22-2011, 01:42 PM   #7
electlatino
electlatino's Avatar
Drives: 2SS with RS and Ground Effects
i had the same questions, and the forum was a lot of help. here's my thread:
http://www.camaro5.com/forums/showthread.php?t=124966
the general consensus is that 1 7/8" headers are best. if you want to go over 500 horsepower, then probably go with 2" headers. i'm not sure how a cam will come into play with all that.
also, getting them ceramic coated is a good idea
JBA full system, RotoFab CAI and w/w relocated, ADM scoop, tune, NLP spoiler....more to come
electlatino is offline   Reply With Quote
Old 02-22-2011, 01:52 PM   #8
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
The OP is asking about cylinder heads...not headers.
S-eatin-grin is offline   Reply With Quote
Old 02-22-2011, 01:57 PM   #9
5thGenCamaroKid
Right - I'm more interested in knowing what the flow numbers mean. In other words, is there a general rule that we/I can adhere to when looking into getting some aftermarket heads, or porting and polishing the factory ones; i.e. is more flow better? when does a high flow become detrimental? how does a cam need to be matched to the head flow? intake considerations?
EDIT: For example, LG Motorsports lists AFR 205s w/ 59cc chambers as one of their possible heads/cam packages. What do they numbers mean and how do I digest them when thinking about moving forward?
Old 02-22-2011, 02:44 PM   #10
electlatino
oops, sorry!
Old 02-22-2011, 08:09 PM   #11
5thGenCamaroKid
Any one else chime in with some knowledge?
Old 02-22-2011, 08:14 PM   #12
bowtienick
bowtienick's Avatar
Drives: 2010 ss m6
check out hot rod magazine. they just did a comparison of ls3 type heads on a 468 that made over 700hp even with the stock heads. i think you can get the article on line.
bowtienick is offline   Reply With Quote
Old 02-24-2011, 06:07 PM   #13
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
This is probably more than you asked for but here goes.
Higher flow numbers move more air and fuel. Larger motors need higher numbers to make power but an LS3 may not. This is a small block. You can hog out a port and flow high numbers but loose horsepower because you loose velocity and air speed which make horsepower. Many porters now try to smooth out exhaust air flow rather than max out exhaust CFM flow.
Mid lift flow is more important than maximum flow because average horsepower is more important than maximum horsepower. Low rate flow is even more important on a street car that will seldom see over 4000 rpm any way. High lift flow rates are more important for high rpm power. Flow rates over .6 lift are not relevant to a cam that only has .610 or .620 lift. The valve will never open to .7 or .8 lift.
I have a 231/247 duration .617/.624 lift 113 LSA cam. I think this cam is too big and plan on a 231/236 in the near future with a 114 LSA. The duration spread was too big before and now my heads flow percentage is better so less exhaust duration is needed. A little wider LSA will spread the horsepower over a wider range and make the cam less peaky and more streetable.
I installed TEA ported heads (L92's, this is the early LS3 head and almost identical) on my LS3 that were rated at 355 cfm intake at .600 and 264 cfm exhaust at .600 and LOST 15 HP on the dyno. Went to the track to verify and ran slower. Pulled the heads and flowed them and they flowed 344 intake and 220 exhaust at .600. Way too skewed to make power. Flow within 80% of intake to exhaust is usually best. So much for advertised flow numbers.
I worked with a local head porter with a flow bench and we got my stock heads Intake flow at .600 up from 306 to 320 and exhaust up from 210 to 242. The exhaust needs more work for a better intake to exhaust ratio so that you don't have to spread the duration numbers so far apart on the cam. You do not want to loose velocity on the intake by increasing flow. Many heads are rated by the size of the intake port. For example AFR has a 185, 205 and 225 head. This is the cc size of the intake port. A bigger motor needs a larger head for more flow. A smaller motor needs a smaller head. The bigger head may make more maximum horsepower with a loss of average horsepower or it may make less horsepower because the smaller motor can not keep up with the flow.
A lot of old school porting tricks such as air foiling the intake and exhaust guides bosses in the bowl don't help LS3 heads. These heads are very efficient out of the box. They do benefit from combustion chamber reshaping and short side radius smoothing on the exhaust. GM was more concerned with a clean burn than max power. Taking the bump out of the quench area on the spark plug side and laying it back at a slight angle allows the piston to push the air into the exhaust more efficiently. Almost all race head combustion chambers are straight across and slightly laid back on the header side.
I picked up the 15HP I lost plus 10HP more at peak and 12 to 15HP more in midrange. Added 2mph on top end at the track. But I also re-geared so top end could have been affected by the gear change.
The only real test for better heads is a dyno or the track on a similar size motor. You can't trust flow ratings to be accurate or better for your combination. I would not get an out of the box CNC job. Some after market heads MAY be better but you have to look at the size motor and intake (fast = $900.00) and throttle body ($300.00- $500.00). A stroker motor or blower motor needs different heads than a stock motor and cam.
The recent series (3, I believe) of Hot Rod magazine tests did not test a stock LS3 size motor. The cubic inches were less for earlier motors or more for stroker motors. The Mast Black Label redesigned head is very expensive and a blower or stroker is needed to take advantage of it.
You can save money on an intake by getting a VMax ported intake. The VMax ported throttle body is more effective with a Vararam or New Era straight shot intake than a curved tube intake. I picked up 15HP with the VMax ported intake and throttle body ($150.00 each). Pete at VMax told me the ported throttle body would increase response and drive ability more than increase horsepower and it did both. I did not dyno the intake and throttle body separately.
I would recommend sending your stock heads to Darren Morgan. He is a top national porter and involved with Engine Masters every year. He has offered to port, mill, valve job and assemble, with your new springs, retainers, etc., for $599.00 on this thread http://www.camaro5.com/forums/showth...t=42255&page=5. This thread also has a lot of good information about head porting.
This is a super price and a good valve job is as important as air flow. Racing valve jobs have 3 to 5 angles and the angle degree and width is all important. Milling helps increase compression which is good for a cam but reduces deck thickness which is bad for blower or nitrous. Also be careful with cams over .600 lift because of valve to piston clearance with milling. Some head shops charge $200 to $300 just to mill, valve job and assemble heads. You should upgrade the stock roller rocker trunion bearings with better springs but roller rockers are not necessary. The pro's and con's of this goes on and on. Dual springs are better with a cam and power adder. I also think patriot springs, even gold springs, are not near as good a comp cam tool steel. The tool steel retainers are cheaper than titanium but lighter than standard retainers. I shift at 7,000 rpm.
nuptualnemesis is offline   Reply With Quote
Old 02-24-2011, 06:23 PM   #14
5thGenCamaroKid
Mid lift flow is more important than maximum flow because average horsepower is more important than maximum horsepower. Low rate flow is even more important on a street car that will seldom see over 4000 rpm any way. High lift flow rates are more important for high rpm power. Flow rates over .6 lift are not relevant to a cam that only has .610 or .620 lift. The valve will never open to .7 of .8 lift.
I have a 231/247 duration .617/.624 lift 113 LSA cam. I installed TEA ported heads (L92's, this is the early LS3 head and almost identical) on my LS3 that were rated at 355 cfm intake at .600 and 264 cfm exhaust at .600 and LOST 15 HP on the dyno. Went to the track to verify and ran slower. Pulled the heads and flowed them and they flowed 344 intake and 220 exhaust at .600. Way too skewed to make power. Flow within 80% of intake to exhaust is usually best. So much for advertised flow numbers.
A lot of old school porting tricks such as air foiling the intake and exhaust guides don't help LS3 heads. These heads are very efficient out of the box. They do benefit from combustion chamber reshaping and short side radius smoothing on the exhaust. GM was more concerned with a clean burn than max power. Taking the bump out of the quench area on the spark plug side and laying it back at a slight angle allows the piston to push the air into the exhaust more efficiently. Almost all race head combustion chambers are straight across and slightly laid back on the header side.
This is a super price and a good valve job is as important as air flow. Racing valve jobs have 3 to 5 angles and the angle degree and width is all important. Some head shops charge $200 to $300 to mill and assemble heads. You should upgrade the stock roller trunion bearings with better springs but roller rockers are not necessary. The pro's and con's of this goes on and on. Dual springs are better with a cam and power adder. I also think patriot springs, even gold springs, are not near as good a comp cam tool steel. The tool steel retainers are cheaper than titanium but lighter than standard retainers. I shift at 7,000 rpm.
Wow - thanks for all the great info, man! Your explanation definitely helps in the deciding whether or not to pursue aftermarket heads.
Need help choosing the right heads and cam to run 11's!! blk5genss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-07-2011 09:57 PM
Ported Heads & Options for LS3 calbert1999 Tuning / Diagnostics -- engine and transmission 32 02-24-2011 06:18 PM
What HP/TQ are stock LS3 heads good for? blake-b Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 01-02-2011 07:47 PM
Trick Flow CNC Cylinder Heads Coming Soon Jason@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-08-2010 02:19 AM
