Old 04-24-2011, 05:59 AM   #1
SKERIS
SKERIS's Avatar
Drives: Jewel Red 2SS RS A6
Tranny Fluid Levels
Hey Guys
Is it true that ONLY a dealer can check the fluid levels in the A 6?
Anybody out there done it themselves?
Thanks
SKERIS is offline   Reply With Quote
Old 04-24-2011, 11:34 AM   #2
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
Here is what the operators manual says
"Automatic Transmission
Fluid
How to Check Automatic
Transmission Fluid
It is not necessary to check
the transmission fluid level.
A transmission fluid leak is the
only reason for fluid loss. If a leak
occurs, take the vehicle to your
dealer service department and have
it repaired as soon as possible.
The vehicle is not equipped with a
transmission fluid level dipstick.
There is a special procedure
for checking and changing the
transmission fluid. Because this
procedure is difficult, this should
be done at the dealer service
department. Contact the dealer
for additional information or the
procedure can be found in the
service manual. To purchase a
service manual, see Service
Publications Ordering Information
on page 13‑15.
Change the fluid and filter at the
intervals listed in Scheduled
Maintenance on page 11‑2, and
be sure to use the fluid listed in
Recommended Fluids and
Lubricants on page 11‑6."
So they want u to take it to gm for checking.
Did some searching and did not find how it is done.
cmore is offline   Reply With Quote
Old 08-16-2011, 11:47 AM   #3
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
You could install a dipstick. That is what I am going to do.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 08-16-2011, 02:13 PM   #4
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
If you have a lift, or can get it level on 4 jack stands, its doable. (Still a pain though)
The "drain plug" in the bottom of the pan is actually the fill check plug.
With the engine running, and trans fluid warm to hot, remove that plug, and very little fluid will come out (unless its overfilled or the vehicle is unlevel).
You can fill it through the dipstick hole (where a dipstick should go), until it starts to drain out of the bottom plug, then it is the proper level.
JDP Tech is offline   Reply With Quote
Old 08-16-2011, 02:40 PM   #5
Patrick G
Drives: 2009 Pontiac G8 GT
But make sure the transmission temp is between 30-50C (85-125F). If the transmission temp is hotter, then the fluid level will be higher and you'll actually drain out too much fluid. This is the #1 leading cause for underfilled transmissions. You must check it within this temperature window or you will have an underfilled or overfilled transmission.
2013 Corvette Grand Sport A6 Forged 416, Greg Good ported TFS 255 LS3 heads, ECS NOVI 1500 blower, 222/242 .629/.604 121LSA EPS cam, ARH 1 7/8" headers, NPP exhaust, 747rwhp/709rwtq on 93 octane, no meth, w/stock street manners.
2014 GMC Yukon XL Denali, Air Raid MIT, tuned.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph Texas Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 Texas Mile
LS1,LS2,LS3,LS7 Custom Camshaft Specialist
Patrick G is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
V6 manual tranny fluid & the 1-2 shift gahammerle Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 04-15-2011 09:07 AM
Diff Fluid and Tranny Fluid jagan323 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 11 03-15-2011 07:45 PM
TRANNY FLUID - IS IT A SPECIAL FLUID?? sask-man V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 11-16-2010 09:01 PM
Rear Diff and Tranny Fluid Change Meet? Infern0 USA - Mid-Atlantic 5 04-08-2010 11:34 PM
