Old 05-05-2011, 10:06 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Disable DRLs
Is there a simple fuse I can pull to disable the DRLs? I don't care about the fogs going on instead, I prefer to have all the lights off in the day. Thank You
JohnZ is offline   Reply With Quote
Old 05-05-2011, 10:21 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Just unplug the harness from the bulb. That'll do it
Click to view my build thread
Old 05-05-2011, 10:42 PM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
LOL, he has a non RS car, so he needs to use relays to do this mod.
Old 05-06-2011, 03:29 AM   #4
JohnZ
JohnZ's Avatar
Is it a particular relay that i need to buy?
Old 05-06-2011, 04:11 AM   #5
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Take the switch apart and cut the spring. You can turn it all the way over to "off" and it will stay there. Super-easy, and free.
Tallboy is offline   Reply With Quote
Old 05-06-2011, 08:53 AM   #6
The Stig
The Stig's Avatar
Ah. Yea that does make it more difficult.
Old 05-06-2011, 10:55 AM   #7
2SSRS@Gen5diy
Here is what you do get and extended harness, like this one.
Then cut the low beam wire in the center, then wire it in to this relay.
Wire it on the switched side then all you do is t-tap the running light and ground the outer side of the wire, This will let your headlight come on automatically at night and not on all day long and you dont have to move the headlight switch.
That is the way to do it if you like moving the switch at night.
Old 05-06-2011, 12:06 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Based on the orignial statement about the fog lights it sounds like he might have an RS?
If you have an RS unplugging the bulb should work.
If you don't have an RS you need this
http://www.moderncamaro.com/forum/sp...d-harness.html
Build Journal
Old 05-06-2011, 01:44 PM   #9
AUS10BMX
Drives: 2010
Do this! I actually cut the little plastic piece that the spring rebounds off of. I think this is the the simplest and free way. Then just turn your lights on at night. I run 6000k fogs and drl switchbacks during the day.
AUS10BMX is offline   Reply With Quote
Old 05-06-2011, 03:00 PM   #10
caverman
caverman's Avatar
Agreed....free and relatively easy to do. As long as he knows that he'll loose his auto headlight feature and will have to manually turn on the headlights at night and turn them off manually as well.
That's something I didn't want to loose which is why I went in search for a plug-n-play harness. Now I get the best of both worlds and can be completely lazy about it.
Build Journal
Old 05-06-2011, 03:05 PM   #11
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Good point, but it was a "plus" for me, as I don't like auto-headlamps, either.
Old 05-06-2011, 09:11 PM   #12
JohnZ
JohnZ's Avatar
thanks for the info guys, i will look into that harness
Old 10-19-2012, 02:15 PM   #13
Vikas2k
Drives: '12 Camaro LS V6 6MT, '09 CX9 GT
Here is what you do ... cut the low beam wire in the center, then wire it in to this relay.
Can you explain the wire connections above more clearly? What color cable, connecting to which part of the relay (control, power, output, ground) etc.
I have the extension cables, relay and wiring ready. I have eagle eyes installed already and my halos are connected to parking light. Similar to you, I want the DRL turned off during the day (and headlights can turn on at night automatically, ideally, although this is not criticle).
I have the 2012 LS.
Vikas2k is offline   Reply With Quote
Old 10-27-2012, 02:45 PM   #14
Vikas2k
Would this not throw the lamp out error message on the dash? The bcm is going to detect no current when the lights are turned off.
DIY-Wired DRLs with switch to have full control over DRLs IROCanSS Cosmetics and Lighting Modification Discussions 33 04-13-2015 10:27 PM
Permanently keep DRL's on Andy_10 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 08-14-2013 01:31 PM
Who has been successful at completely disabling DRLs? Callaway Chris Cosmetics and Lighting Modification Discussions 7 03-07-2011 11:41 AM
Daytime Running Lamps (DRLs) Universal Remote System stlrammer 5th Gen Camaro SS LS LT General Discussions 8 01-31-2011 12:22 PM
K I have a weird problem with my 2ss 2010CamaroOutlaw 5th Gen Camaro SS LS LT General Discussions 45 10-25-2009 12:35 PM
