Formerly Camaroc5
Drives: 2010 Camaro LT/RS M6 Join Date: May 2010
With everything coming together with my headers and such and tune with ghost cam, I am wanting to achieve a louder idle and for it just to be a bit louder overall. I have 40 series flowmaster and resonator delete. When I put my headers on I will be doing my resonated x pipe as well. Any thoughts? Final set up will be Long tubes, high flow cats, resonted x pipe, resonator delete, muffler delete. I DO NOT want it to be super raspy either. That is why I am putting on my xpipe.
Darn I put "off" instead of "of" in the title |
![]() Drives: '02 Camaro SS & '10 Sierra Denali Join Date: May 2011
It will be raspy if you do a muffler delete. I would do exactly what you are doing except leaving the flows. Good choice on everything but leave the flows
DD 2010 GMC Sierra Denali 6.2L AWD, K&N CAI, Flowmaster 2002 Camaro SS SLP Loudmouth, SLP lid, K&N, T-tops, 6-spd, 25,000 n counting ![]() |
Formerly Camaroc5
Thanks. It is sad the the long tubes will add to the raspyness. At least that it was I have read. I was just hoping the resonated xpipe would fix it. Trying to think of what is louder than a chambered flowmaster. Maybe some glasspacks?
#4 | |
There's a guy on here, I think BaylorAirForce, who put a resonated x-pipe on his setup and it helped the rasp a lot. There's examples of the sound clip in the exhaust samples sticky. As for my setup, it used to be very raspy in the first mile or 5 mins I drove, once the pipes warmed up and the carbon built up it was deep as hell. The raspyness has actually lowered after 1 year of driving with them on, chalk that up to the carbon build up. BTW.......I have said this before.....unless you are driving a straight 6, any exhaust modification will to a v6 will increase the rasp. It's the nature of the beast. You can manage it, but brand new mods will have rasp until they get good usage and they will be reduced but not completely gone.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
If you put glass packs on ANYTHING I will be forced to make fun of you. Can't believe that even crossed your mind LOL
#6 |
C5 THAKILYETI
Drives: 2LTRS Join Date: Aug 2010
I totally understand where you are coming from, but I think you maybe ought to try something like the MRT v1, which advertises an aggressive idle but will still have a refined tone without much rasp...
The flowmasters seem like they idle down to just as quiet as stock. They sound great when you get on the gas under load, but at idle they sound rather quiet. Is this because the muffler chamber is larger that the idle is so quiet? The mrt v1 is actually a pair of resonators that are fashioned into an axleback kit, they are only a little larger than straight pipes would be... |
#7 |
Formerly Camaroc5
Yes i know...just thinking out side the box. Did you know our camaros come with glasspacks?? The resonators are pretty much the same thing as a glasspack
#8 |
![]() Drives: 2011 Camaro LS Stripper model Join Date: Feb 2011
I have done the mufler delete and cold air intake. She is pretty damn loud for around town. Once out onto the hwy it never bothers me. Cold start-ups can be heard inside the neighbors house two doors down. I have been contemplating short glass packs behind the rear axle for some time now. I have been told that the closer to the tips the less rappy glass pack sound you get. I found some aluminized glass packs somewhere that were only 12 or 14 inchs long and cheap(Heartthrob maybe). Seem like the perfect fit just gotta try it.
#9 |
Eat. Sleep. Race.
I have a muffler delete and an X-Pipe and I'm happy with it. Don't exepect your HP numbers to go up, but if your looking for sound then the LT's will help for sure.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I am of a different opinion than some of the other comments left here. I think LTs + high flow cat + magnaflow resonated X could possibly work just fine. There are members here with videos of just the resonated X with no mufflers out back and they don't sound bad at all. Now, I'd never go LTs + straight pipe all the way back, but with the resonated X I think you should give that a try and get back with us on the results.
If you end up not liking it, then try adding the flows back into the mix...and lucky for you, my sticky thread has a setup EXACTLY like that (BBK LTs + resonated X + flowmasters) and I think it sounds sweet with nice rumble. Give it a listen. Hope you didn't mean that LTs will not add much HP, because they most certainly will add a nice amount of power. But if you was just referring to the X pipe + muffler delete, then yeah, probably not too much power gained there.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#11 |
Formerly Camaroc5
I really want to try the muffler delete. I don't really want to cut them off losing tips then having to pay for piping and welds and such to get the tips back in the outlets...or pay to have the mufflers welded back on lol...how much do you guys think it would be to have piping to replace the mufflers and tips and everything welded?
#12 |
Formerly Camaroc5
So what is the verdict? My exhaust now is super raspy if pipes are not warmed up. And even after 3-5k rpms can be raspy. So adding long tubes, high flow cats, and a resonated xpipe(have resonator delete)...will muffler delete make it more raspy? I'm looking for louder and deeper.
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 2011 LS Join Date: Oct 2010
I think any muffler delete will equal rasp.
#14 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
One of the guys posted a video up on his V6 after installing a DT Muffler Delete Kit on that particular thread in the marketplace.
Perhaps that video might help ya a little. Good luck! Ivan
| Question for those with muffler delete | daphatgrant | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 10-26-2010 04:27 PM |
| Muffler Delete or Pypes Cherry Bomb on 2010 SS? | gtothep123 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 09-14-2010 03:39 PM |
| DIY at home Muffler Delete for $20 | CDBiker220 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 10-12-2009 06:32 PM |
| MUFFLER DELETE | Mungo | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 09-28-2009 08:15 PM |
| To muffler delete or not to delete | BumbleBeeSS2009 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 81 | 06-25-2009 04:55 AM |
