Old 07-02-2011, 04:55 PM   #1
chevpwr
chevpwr's Avatar
Drives: 2007 S/C C6 Corvette
Coolent Temp
What coolent temp does your car have with a 160 thermostat dirving at 60-70 mph? Before I changed it, it would reed 200-210, now with the 160 it reads 186-190. I would think it would be less. This is on a 85-90 degree day. I don't usually dirve it when it is hotter than that.
chevpwr is offline   Reply With Quote
Old 07-02-2011, 05:12 PM   #2
Synner
Drives: cars
The thermostat only determines what temp it opens the cooling system; it doesn't mean your coolant will be 160. Without changing your fan switching points with a tune you won't see a major change. Plus you reach a point where cooler isn't better.
Old 07-02-2011, 05:16 PM   #3
chevpwr
chevpwr's Avatar
It was tuned for the 160. I didn't think it would run 160. The factory one is rated at 92.2c which is around 198, I just figured with the 160 it would run 30 or so degrees cooler.
Old 07-02-2011, 05:51 PM   #4
Synner
Drives: cars
No that won't happen. If you still want it cooler you should look at adding an additive like water wetter or purple ice. It won't have much of a change either since you're pretty close to optimum already. It would only help if you did some road racing where the rpms stayed high and you were actually getting the system a lot hotter. Oklahoma gets cold so I wouldn't reduce your coolant percentage to get better heat dissipation from more water. Realistically your temp is perfectly good so you don't have to do anything.
Old 07-02-2011, 06:45 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
unless you program your ecm with a custom o/s you dont have any control of the fans below 192*f,, i have a custom o/s in mine and i can control the fans all the way down too 163*f
also you have to remember the temp sender is located in the cylinder head and the thermostat is in the waterpump
Old 07-02-2011, 06:49 PM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
On an 85-90 * day I'm around 182-185 or so .. seems your right in line ..
Crowley
Crowley is offline   Reply With Quote
Old 07-02-2011, 06:51 PM   #7
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Crowley
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 07-02-2011, 06:55 PM   #8
chevpwr
chevpwr's Avatar
Originally Posted by Padre View Post
Padre
Thanks guys, just checking!
Old 07-03-2011, 05:02 PM   #9
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
[QUOTE=Crowley;3416349]On an 85-90 * day I'm around 182-185 or so .. seems your right in line ..
I agree with Crowley above. My temps are right close to where he is as well and we both drive in hot Texas heat. You are firne. Also my tranny temps droped about 10 to 15 degrees as well on my Man 6 car after the stat change.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Outside Air temp sensor reads high My 5th 5th Gen Camaro SS LS LT General Discussions 55 06-26-2016 08:02 PM
What is YOUR LLT operating temp? mpiper Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 9 04-30-2011 09:05 PM
A/C turned hot, and the engine temp rose Bonemaro 5th Gen Camaro SS LS LT General Discussions 17 07-20-2010 09:04 PM
Oil Temp gauge - low oil temp! andyscozz Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 8 05-11-2010 10:20 AM
SECOND GEN WATER TEMP GAUGE INACCURATE 79ZRAG 1st & 2nd Generation Camaros 9 05-30-2009 06:13 PM
