Old 07-11-2011, 05:17 PM   #1
2SSRSTUVWXYZ
2SSRSTUVWXYZ's Avatar
Drives: 2010 2ss rs sim camaro
Question GILL INSERT HELP!!
i'm looking for black gill inserts for the camaro and i would like your opinions and experiences with the different types... the hard plastic or the vinyl stickers....close up pictures of the plastic ones would be appreciated looking to order ASAP!!! hoping this will be enough to hold me over before i buy my next upgrade this fall/winter..... i'm suffering from MOD FEVER!!!thought these "smilies" fit well lol
2SSRSTUVWXYZ is offline   Reply With Quote
Old 07-11-2011, 05:49 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
get the vinyl ones. I originally had the plastic ones, but they didn't fully stick to the gills because they couldn't conform to the correct shape. Ended up having to take em off and put the vinyl ones on.
Click to view my build thread
Old 07-11-2011, 07:39 PM   #3
2SSRSTUVWXYZ
thanks how hard is it to position the vinyl ones?
Old 07-11-2011, 08:01 PM   #4
montreal2010yellow
montreal2010yellow's Avatar
Very small parts if you're not experienced just damp the gills with water and a drop of dish waher liquid, it alloews you to move them, then take a air dryer at medium heat to secure every thing and we all dry take off the protective cover orver the vinyl...
Old 07-11-2011, 08:50 PM   #5
The Stig
The Stig's Avatar
It's really not. Like the above post just put some soapy water on the gills and then apply the vinyl. It'll let you move them around and get them just right. Then use a credit card to squeegee out the water.
Old 07-11-2011, 08:53 PM   #6
Black Lightning
Black Lightning's Avatar
Drives: 2011 Camaro 2SS/RS
I got the GM gill stripes. Very happy with the quality.
Red hood spears; Corsa cat-back exhaust; Roto-fab intake; Engine bay black/red theme; Black outs including both bowties, tail lights, tail light bezels, and side lamps; gill stripes; 35% window tints; Side SS badges; Hurst-equipped badge.
Black Lightning is offline   Reply With Quote
Old 07-11-2011, 09:41 PM   #7
2SSRSTUVWXYZ
Thanks probably will order the GM ones!
2010 2SS RS, borla "S" type catback, cold air intake, aac side markers, vinyl wrapped taillight bezels, chromed turn signal bulbs, slp ss bowtie replacement, mpd1 spoiler, ZL1 rocker molding, texas speed headers, tune
Old 07-12-2011, 06:23 AM   #8
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
I have the RPI ABS inserts and if you can get them to fit well they look good but you have to heat them and form them before you install them. If not then they pull away in the corners and look like crap
godeepdown is offline   Reply With Quote
Old 07-12-2011, 09:42 AM   #9
hotrodrick
Drives: 2010 2ss 6 speed
qtr gills
i build custom cars and from what i've seen out there retrousa stuff
is as close to original appearance as anything else available. quality and fit is
excellent. they have both chrome and black/paintable
hotrodrick is offline   Reply With Quote
Old 07-12-2011, 03:48 PM   #10
Tiberious
Old '71 Owner
Drives: 11 Camaro Vert;97 Malibu;03 Venture
I did a little digging around and simply can't justify the nearly $200 for the GM ones. Saw some nice decals out there that go from clear to black in grade which gives more of the appearance that they're not molded plastic and give a more realistic vent look. I was hoping to find the chromed or satin ones that incorporate the graded black inset but haven't as yet. I'm disappointed that that style doesn't appear to stay on as steiger pointed out. Has anyone else experienced this problem? I'll check out the retrousa stuff as you suggest hotrodrick, any other suggestions out there?
Tib
Tiberious is offline   Reply With Quote
Old 07-12-2011, 05:43 PM   #11
2SSRSTUVWXYZ
was thinking the slp fade ones might do for me but i'm going to try to make my own and see how that works out.... i figure once i have a good template to work from i can reverse it for the other side it won't be that hard and save the 50-200 dollars
gills
RPI Designs Side Vent Insert (Gill) installed Bumble_Bee Cosmetics and Lighting Modification Discussions 50 04-19-2012 08:38 PM
RPI gill insert help. godeepdown Cosmetics and Lighting Modification Discussions 12 07-07-2011 04:25 PM
New gill inserts on the Indy Pace car.... InfernoMan2011 Cosmetics and Lighting Modification Discussions 17 04-27-2011 10:34 PM
Retro USA Gill insert mod. daveagogo1 Camaro Photos | Spyshots | Video | Media Gallery 16 02-11-2011 05:50 PM
Some Defenderworx Gill Insert Pics alexw Cosmetics and Lighting Modification Discussions 4 05-22-2010 02:14 AM
