Old 07-24-2011, 12:52 AM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Question for those of you V6'ers that change their own oil
So I decided to start doing my own oil changes, however I've looked at this video
http://machinezealots.blogspot.com/2...can-final.html
and this guide
http://www.camaro5.com/forums/showthread.php?t=79739
I could not find any oil plug on the side of the oil pan at all. I even had my buddy check it out. The only plug I could find was at the bottom of the oil pan. I have a 2010 Camaro, did they change the oil pan at all on the V6, or am I just missing something?
BaylorCamaro is offline   Reply With Quote
Old 07-24-2011, 01:18 AM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Can you take a picture? There's no drain plug on the passenger side?
Old 07-24-2011, 01:33 AM   #3
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
I'll take a picture tomorrow, kinda late right now and with my car lowered and after market cats you can't see a thing unless you jack it up.
Nope nothing on the side unless I'm totally blind..
Old 07-24-2011, 01:44 AM   #4
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
The only bolt that faces down is the transmission plug I believe. Double check again, it's there lol. I think it's on the same side on the V8s as well.
jagan323 is offline   Reply With Quote
Old 07-24-2011, 02:14 AM   #5
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
camaro5.com/forums/showthread.php?t=100836 well it def wasn't this
Old 07-24-2011, 02:37 AM   #6
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
No offense, but are you sure you were looking in the right place?? If you're seeing something on the bottom it sounds like you're looking at the underside of the transmission. The plug should be on the passenger side, look at your lower A-arm on the pass side front suspension and go directly in from that and you should see a 15mm drain plug bolt head.
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 07-24-2011, 02:50 AM   #7
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
No offense taken, that's why I'm on the forums, to learn haha. Anyways, I was under the car right by the passenger side between the two cats
Old 07-24-2011, 02:55 AM   #8
VEESIKS
formerly 2011Camaro
If you are looking between the cats and you have LTs you are too far back. Best way I can tell you to do it is get under the car, find the harmonic balancer (crank pulley) come straight down from there to the front of the oil pan, come around the passenger side and you should run right into it.
Semper Fidelis
Old 07-24-2011, 03:24 AM   #9
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Ok after looking at the video again at around time 0:54 you see the oil pan and behind it is another pan which is what I think is the transmission fluid. The bolt I was looking at I believe is the check tranmission level. As noted here (look at post #7)
http://www.camaro5.com/forums/showthread.php?t=120571
If anyone would like to confirm this that would be great.
Old 07-24-2011, 08:14 AM   #10
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Bub......quit looking at the V8 Engine......
Look at the second picture.....that's what the plug will look like at the bottom of the engine block on the passenger side. I have done all my changes.....it's there
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 07-24-2011, 05:00 PM   #11
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
After further examination I'm just an idiot. Anyways, the oil is now changed, thanks for the help guys.
Old 07-24-2011, 06:27 PM   #12
PoorMansCamaro
Drives: Really Slow
Lol
Old 07-24-2011, 06:38 PM   #13
Bill F
Bill F's Avatar
Drives: 2011 CGM 2LT/RS 2005 Silverado Z71
You are only an idiot if you didn't reinstall the plug before adding oil.
Bill F is offline   Reply With Quote
Old 07-24-2011, 09:59 PM   #14
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Thankfully I remembered that part.
A Look at GM's Oil Life Monitoring System franknbeans Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 168 08-07-2024 02:29 PM
Oil change today at dealer ... question SummitWhiteLS Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 47 03-05-2011 08:59 AM
oil change question... LDGn63 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 06-09-2009 07:19 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
