Old 09-04-2011, 11:26 PM   #1
Amenti
Amenti's Avatar
Drives: 2017 1SS Convertible
V6-to-V8 Differential Swap
So, after two days and almost three nights of bungling around under my car with a friend in my driveway, I've finally completed conversion from my 3.27 Ratio V6 Automatic Open Differential to the 3.45 Ratio V8 Manual LSD.
I just barely finished throwing it all together; so, I've only driven it around gingerly to distribute the gear oil in the differential. It sounds like everything went well, and there's no strange creaks or groans coming from the IRS. There was a little bit of what I think is exhaust rattle; but, I think I know where that's coming from. I had a clamp a little close to the rear subframe.
So, I'll install the tune to correct the speedo tonight, and do some hard launches tomorrow to see how she performs.
Performance Mods: Injen Powerflow CAI, Doug Thorley Cat-Back Exhaust, Doug Thorley Shorty Headers, Trifecta Tune, TSW Nurburgring Wheels 20x9, 3.45 Ratio LSD Swap, VMax Black Ice-Olator
Appearance Mods: RiderGraphix LS7 Front Fascia Blackout Vinyl, Gill Insert Vinyl, Rear Deck Lid Vinyl (Gloss Black), Gary's Customs Painted Bowties
Coming Soon: BMR Trailing Arms
Amenti is offline   Reply With Quote
Old 09-04-2011, 11:27 PM   #2
KMPrenger
KMPrenger's Avatar
Great! Hope there are no issues and looking forward to your impressions.
Old 09-05-2011, 12:34 AM   #3
Spicoli
Spicoli's Avatar
Drives: 2010 Camaro 1LT/RS
I'm interested in doing the same mod. What did you have to change? Diff., axles, driveshaft?
Thanks!!!
All I need are some tasty waves and a cool buzz and I'm fine (and of course a hot Camaro doesn't hurt).
Spicoli is offline   Reply With Quote
Old 09-05-2011, 10:28 AM   #4
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Great news man!
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-05-2011, 10:48 AM   #5
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Old 09-05-2011, 11:16 AM   #6
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Curious about this. What is the approximate cost of this swap?
OOLIE is offline   Reply With Quote
Old 09-05-2011, 11:19 AM   #7
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
what to do the same,will be back agian to see some of the answers to the questions
its a syn is offline   Reply With Quote
Old 09-05-2011, 01:38 PM   #8
SC2150
We have a complete rear drivetrain to do the swap in house waiting for the next TT build if someone wants it done.
Old 09-05-2011, 02:02 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Very impressive "driveway" job! Nice work.
I was happy completing subframe bush inserts, way to bring me down a notch!
Off topic but big improvement with those light Nurburgring wheels?
Old 09-05-2011, 04:36 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Old 09-05-2011, 05:43 PM   #11
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
Originally Posted by Apex Chase View Post
Interesting about the MAF sensor, does that also include the V6 community? I am thinking Vararam would have information about that?
Ir0nM4n is offline   Reply With Quote
Old 09-05-2011, 06:09 PM   #12
Amenti
Amenti's Avatar
So, I've been out driving in city traffic for a while today. I was able to give it a few good launches, and it feels very peppy. The butt dyno tells me there's a slight increase in realized torque with that new differential. The launches are also very smooth. My exhaust rattle went away after repositioning the clamp I had too close to the subframe.
On a side note, I used to have a strange crunching sound shifting from first to second. I believe there's a TSB regarding the problem that states there's a washer missing from the axleshaft near the wheel bearing hub. The SS axles I used had those washers; so, that annoying little crunch is gone now!
@Spicoli: In order to do the swap, you need the differential, some SS axles, new wheel bearing hubs to fit the beefier axles, and possibly an SS driveshaft. The only difference between the SS driveshaft and the V6 driveshaft appears to be the coupler bolt pattern; so, in theory, if you had a V8 coupler to put on your V6 driveshaft, you'd be alright. Definitely check on that, though.
@Ventmaster: The Nurburgring wheels were a great investment. It made the car feel lighter on its feet due to the 7+ lbs. reduction per wheel. Also, going to a 1-inch wider front wheel made the car feel a little less squirrely on uneven pavement. Your results may vary!
@OOLIE: Let's see...I got a deal on a brand new 3.45 SS rear diff on Ebay for 600+95 shipping, new wheel bearing hubs are 140+ each, got a new driveshaft on Ebay for 290 and free shipping, i got the axles slightly used from a C5 member for 150 for the set (I think). Plus, I paid 600 for my Trifecta tune (13hp at WOT is nice) for the corrected speedo. Self-installed; so, a total of: $2020.00.
It seems a little steep; but, I'd say it's worth it to get your LSD, some beefier drivetrain components and access to all of the SS aftermarket gears.
Old 09-05-2011, 08:05 PM   #13
Apex Motorsports
You guys are not effected. It is just an SS problem.
Old 09-05-2011, 08:28 PM   #14
Spicoli
Spicoli's Avatar
@Amenti Thanks for the response. I guess I'm on the search for a donor car.
Pros and Cons of Cold Air Intake on a V6 vs. Cold Air Intake on a V8 BowtieBelle Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 07-21-2011 03:22 PM
V6 auto differential swap to a SS,V6 manual? PieNsky V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 02-16-2011 08:55 PM
V6 Camaro VS V6 & V8 Stangs xpanda305x Chevy Camaro vs... 17 05-04-2010 12:06 AM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 01:29 AM
If gas goes up, then get the V8 !! Patriot 5th Gen Camaro SS LS LT General Discussions 37 04-28-2010 02:31 PM
