Old 10-05-2011, 09:36 AM   #1
Kerr
Drives: 67 vette
burning smell.
IM a retard. should have just put this in the other topic as one big topic...
I have the GM performace exhaust... If any other of you have it did it smell like burning metal? we get a new GM car every year and ive never owned on that smells like melting metal, etc...
Today i drove to work, only 5 miles.. temp gauge and everything normal, but you just get this smell... think of it as the smell you get when you weld up exhaust tubing.. It doesnt smoke, just the od on fire metal smell... Maybe im just use to the SUV side of GM... at any rate they rate a new suv or truck, or impapa for that matter doesnt smell like its melting..
I looked at the bumper, thought maybe it was touching.. its not... plastic isnt even warm... so im guessing its just the GM performace exhaust making that smell.. or maybe thats just they way camaros are until something is burned off...
Kerr is offline   Reply With Quote
Old 10-05-2011, 09:40 AM   #2
Rizzo
Drives: 2012 Camaro ZL-1 SIM
Hum...I have the GMPP Catback and didn't notice that. I have had it for two years now with no issues. Weird.
Rizzo is offline   Reply With Quote
Old 10-05-2011, 12:41 PM   #3
Chevrolet Customer Svc
Drives: GM Vehicles
Kerr, you may want to have your vehicle checked. It isn't terribly common but I have seen where something will get caught on the exhaust and cause smell issues. Hopefully it's not that serious and you can roll right back out of the dealer. Let us know if you do decide to take the vehicle in. Thank you!
Jeff Morris, Chevrolet Customer Service
Old 10-05-2011, 04:03 PM   #4
ffrcobra_65
is your car new? if so, you are simply smelling the burning plastic labels/part tags on the exhaust pipes. Or maybe your exhaust is new and the labels/tags are burning off. Either way, it will go away in a few hundred miles or sooner.
Old 10-06-2011, 01:04 PM   #5
Kerr
Drives: 67 vette
yea its brand new 70 miles.. The 2011 denali had smell for a little while but not near like this one has.
Old 10-06-2011, 01:27 PM   #6
elpatofeo
LawBraker
elpatofeo's Avatar
Drives: 10 SIM 2LT/RS & 2016 1SS Hyper Blue
had that happen to me the other day...my friend was driving the car and when she came to pick me up I smelled burned plastic, sure enough I looked under the car and there was a plastic bag stuck on the exhaust. I took it off but it still smells, might take a while for the smell to go away.
elpatofeo is offline   Reply With Quote
Old 10-08-2011, 09:24 PM   #7
Silverwolf
OKCAMAROS.COM
Silverwolf's Avatar
Drives: 2013 2SS / RS
Me too...
Yep ..my baby had a crappy diaper too...lol ...it had that burnt plastic smell ...and sure enough a big ole contractors bag had gotten up in my exhaust ...pulled it off and the smell is still faint after two weeks...
But who cares if it has a little burnt smell... It's a free kin b e a utiful car... And I am proud of my smelly ride! :@)
Love my new lil' Demon.. But gonna miss my red jewel a bunch!
Silverwolf is offline   Reply With Quote
Old 10-14-2011, 06:07 AM   #8
landshark-ss
Drives: 2010 Camaro SS
had a TechConnect Online News Blog
Heater Core Failures and Electrolysis
By Blog Admin on November 7, 2008 4:07 PM | No Comments
Most heater core failures are caused by high flow rate or poor quality coolant. But there's another culprit for repeat heater core failures: excess voltage in the coolant, which leads to electrolysis.
When stray electrical current runs through the cooling system, it can cause metal to be removed (pitting, scarring) from the heater core and result in leaking within the core. Electrolysis may be caused by a lost ground or if the coolant has become corrosive.
To combat the damage caused by electrolysis, ACDelco heater cores use a one-step brazing process to strengthen the joints for high corrosion and erosion resistance and durability.
If the heater core is leaking, examine the location of the leak. If the leak is on the inlet or outlet tubes, it is most likely due to high flow rate. Review the appropriate Service Information, which may call for the installation of a restrictor on the inlet hose, facing the direction of the coolant flow (toward the heater core) and close to the engine block.
If any leaks are found in the heater core itself and there are no signs of physical damage, the coolant inhibitors may be depleted and require a check for electrolysis. (Fig. 7)
Voltage Reading
Generally, electrolysis is possible with a Digital Multimeter (voltmeter) reading of 0.3 or higher.
To determine if electrolysis is present, with the engine running, take a voltage reading with the voltmeter negative lead grounded to the battery and the positive lead suspended in coolant, making sure it does not contact any metal part of the cooling system.
Both AC and DC voltages should be checked. Vehicles normally have DC voltages, but a faulty engine block heater or faulty diode in the alternator can produce AC voltages.
Although coolant is lost due to heater core failure, try not to dilute the original coolant with new coolant during testing if possible.
Flush the Coolant
If the voltage in the cooling system is greater than 0.3 volts, indicating electrolysis, perform a cooling system flush using a coolant exchanger, which can replace virtually all of the old coolant with new coolant.
If the cooling system is restricted from scale, rust or other debris (Fig. 8), only an exchanger with a back-flush procedure will be effective. A vacuum-fill exchanger also will purge any trapped air in the cooling system.
Check the Grounds
The most likely possibility for electrolysis is a poor ground somewhere in the vehicle electrical system, such as a cooling fan mounted to the radiator.
Check the grounds on the battery, engine/transmission and body sequentially with the voltmeter negative lead.
Also check various accessories by watching the voltmeter while turning each accessory on and off and also by engaging the starter motor, but not starting the engine.
Next, perform the same checks with the engine running at a fast idle, about 2000 rpm.
Remember, you must check all three grounds (battery, engine/transmission and body) with each accessory and keep the positive voltmeter probe suspended in the coolant. The voltmeter reading is unlikely to drop to zero, but should clearly drop below 0.3 volt. The accessory with the drop has a bad ground.
One other item to keep in mind is that if the vehicle is equipped with an electric cooling fan it should be cycled during the testing and voltage monitored with it on and off.
Don't Ground It
The final word, plain and simple, is do not ground the heater core. If the heater core is grounded, a path is provided for electrolysis to pass through the heater core, which would allow any stray voltage to use the coolant as the ground path.
- Thanks to Dennis Kissack
Categories:
Leave a comment
Sign in to comment.
Name
Email Address
URL
Remember personal info?
Comments
Monthly Archives
Languages
English
French
Spanish
Resources
About this Entry
This page contains a single entry by Blog Admin published on November 7, 2008 4:07 PM.
Tire Pressure Monitor Sensor Service Tips was the previous entry in this blog.
2009 MACS Convention is the next entry in this blog.
Find recent content on the main index or look in the archives to find all content.
burning smell too..2010 ss.. the other morning listening to smoke on the water really loud.. turned the heater on and the car filled up with pink steam..fluid out the vents.. Heater coil!! yep, they have to pull the windshield to replace.. my main worry is why it went out. 35k on the car...this might be your burning smell. i thought my daughter was smoking in the car.. but this might be the problem. see below
landshark-ss is offline   Reply With Quote
Old 10-14-2011, 10:25 AM   #9
PitchBlack
(with a little chrome)
PitchBlack's Avatar
Drives: The Black Knight
I had the same issue on my 2012 Camaro that I have had for less than 2 weeks. I drove it off of the lot for a test drive when it only had 6 miles on odometer. It took about 100 miles of driving before it went away.
PitchBlack is offline   Reply With Quote
Old 11-19-2011, 08:46 AM   #10
CammieChix
CammieChix's Avatar
Drives: 2011 1LT 6-SP MANUAL
I had the same issue when my car was brand new. Those first few weeks my garage would smell like I was making a 1000 pieces of toast every night. Super strange odd burning odor that would take an hour or so to dissipate. I called the dealer about it over and over and got the "that's what new cars do." And so I accepted that and eventually it went away but it took a long time.
Let me just say I've been driving brand spanking new cars for decades and it never smelled like we were frying barbie dolls under the hood. Sad.
CammieChix is offline   Reply With Quote
Burning smell when revving engine denferg Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 46 03-29-2013 11:20 AM
Burning smell on 5k rpms Mdipinto 5th Gen Camaro SS LS LT General Discussions 1 08-25-2011 12:26 AM
Burning Smell started Friday Verio Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 08-19-2011 03:09 PM
L99 Burning Smell At WOT nitto85 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 11-14-2010 06:39 PM
Burning smell SSTony Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 12-14-2009 06:00 PM
