Old 10-05-2011, 01:57 PM   #1
Brian52682
Brian52682's Avatar
Drives: 2011 Camaro SS Convertible
Wax & Vinyl Stripes
So I am going to wax my car for the first time tonight since I've owned it and have heard time and time again not to get it close to the Vinyl Stripes. If you get some on and wipe it off is that good or do you not need to get wax close to the vinyl stripes?
Brian52682 is offline   Reply With Quote
Old 10-05-2011, 02:36 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
If you have the factory flat black, try to avoid them as much as possible. Mine are the factory gloss black, and they aren't so bad to clean the wax off of. I normally just use detail spray on the stripes.
Old 10-05-2011, 02:42 PM   #3
Gator6977
Gator6977's Avatar
Drives: 2011 2LT RS
I wax mine every time. They're after market flat black and end up with a slight shine that's only visible up close.
Gator6977 is offline   Reply With Quote
Old 10-05-2011, 02:48 PM   #4
Russell James
Russell James's Avatar
Stay away from the stripe edges. Two problems if you do. On the flat black stripes, wax can muck them up. On all stripes, rubbing wax against the edges can cause problems with the edges lifting.
The only thing stripes need is to be washed with car wash soap. I keep wax at least an inch or so back to avoid rubbing the edge.
Old 10-05-2011, 03:08 PM   #5
Brian52682
Brian52682's Avatar
Thanks so much for the advice, I do have some TurtleWax Ice detail "wax" that is safe for the vinyl stripes and I'll use that. I will use my Mequiars wax for the rest of my car.
Old 10-05-2011, 05:44 PM   #6
copper3000
Troy
copper3000's Avatar
Drives: 2018 ZL1 Camaro
I use Meguiar's NXT Generation Tech Wax 2.0 and my stripes look great. There isn't any white residue and I can wax everything. It also helps repel dust!
copper3000 is offline   Reply With Quote
Old 10-05-2011, 06:10 PM   #7
The Stig
knows 2 facts about ducks
The Stig's Avatar
The video is from this thread Caring for Factory Camaro Stripes
Click to view my build thread
Old 10-05-2011, 07:03 PM   #8
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
If they're gloss you can wax them, no problems.
If they're matte then no... don't get any wax on them. Mask them off with painters tape if you need to wax close to them.
Old 10-05-2011, 07:19 PM   #9
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Use Turtle Wax Ice on the matte stripes. It will makes them look awesome.
newagemuscle is offline   Reply With Quote
Old 10-05-2011, 07:26 PM   #10
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Matte black I use Pledge spray ;-)
Sent from my iPhizzzone using Tapatalk
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 10-05-2011, 09:27 PM   #11
Bonanza7
Drives: 2010, Rally Yellow, Black stripes
Yep. Turtle Wax Ice. Works great on the stripes
Bonanza7 is offline   Reply With Quote
Old 10-05-2011, 10:54 PM   #12
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
SAME HERE. NO WORRIES.
2010/2SS/RS/6L80E/Mast built LS3 416 Stroker/Black Lable Heads/Blower Cam/Jannetty Tuned/ 685rwhp/635tq/KookHeaders/3"exhaust/Magnaflows/Whipple Blower/10lbs bst/Duel pumps/85lb inj/2 gauge pillar/CAI/RX catch can/Vmax ported TB/Lexani LX15s/Pedders sub F bushings inserts/Pedders sport extreme coilovers/ZL1 sway bars/Hotchkis strut tower brace/Hawk brake pads/stainless steel brake lines/CTV front calibers/slotted rotors 15"/1 pc drive shaft & loop/hidden radar-laser detect/rear louvers/terminator hood/ SS mats/black outs/Bowties/GM GFX kit/blade spoiler/deading matting/wolf art/
Camaro54 is offline   Reply With Quote
Old 10-06-2011, 02:38 AM   #13
NoSloSS
BUMBLWHO
NoSloSS's Avatar
Drives: 2013 Camaro 2SS/RS Convertible
So has anyone used wax on the Dinoc Carbon fiber wrap?? Planning on replacing my stripes with the hexis material (Same as Dinoc, but better for auto use) soon and wanted to know how it turns out or if you need to keep away from them with wax.
NoSloSS is offline   Reply With Quote
Old 10-06-2011, 02:09 PM   #14
cwahl
Drives: 2011 Camaro SS1 RS M6
Dust in AZ SUCKS!!!
cwahl is offline   Reply With Quote
The New Jersey (and area) check-in thread SirBrad USA - NY / NJ / PA 458 06-10-2014 07:13 AM
Wax the Vinyl? QuiksilverHg Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 08-14-2011 12:39 PM
Considering that the Racing Stripes are Vinyl... suplex Cosmetics and Lighting Modification Discussions 12 08-06-2011 04:01 PM
backing tape from vinyl stripes Captain McFunk Cosmetics and Lighting Modification Discussions 1 05-07-2011 02:24 PM
Anyone concerned about the long term effects of vinyl stripes caverman 5th Gen Camaro SS LS LT General Discussions 26 07-31-2009 08:16 AM
