Old 10-21-2011, 03:38 PM   #1
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
VVT 2 cam question
hey guys. I was looking at getting this cam next year. I am making a list of stuff I need. The question is this. Is this cam to big for a dayly driver and would it need a stall.... If so has any one used the VVT 1 cam and what kinda gain could one expect.
I plan to have LT headders with cats, full exhaust, CAI or varram intake, oil catch can, and underdrive pully on the car before I buy all this stuff. Also, who offers a can tune they can email me to get the car running so I can drive it to a DYNO.
Guess I can swap the oil pump wile I am there to.. thanks guys..
mgoodbar is offline   Reply With Quote
Old 10-21-2011, 06:11 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
What are the specs for the cam? Are you a manual or LS3?
Juiced1 is offline   Reply With Quote
Old 10-21-2011, 06:23 PM   #3
mgoodbar
Drives: 2010 L99
L99 A6... not sure what the cam specks are....
Is any one running the VVT-2 texas speed cam?
Old 10-21-2011, 06:26 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
you can drive the car without a tune to the shop, in most cases. what cam are you talking about? variable valve timing cam? we need specs to help. and he meant is it manual or automatic, ls3 or l99
Parag is offline   Reply With Quote
Old 10-21-2011, 06:28 PM   #5
Parag
you really cannot buy a mass produced cam that you cannot drive on the streets. there is no demand for them
Old 10-21-2011, 06:28 PM   #6
mgoodbar
Drives: 2010 L99
TSP L99 VVT Camshaft Package
base price $804.99
item# 25-L99VVTCamKit
|Share
Your Choice of Camshaft, PRC Spring Kit, and Hardened Chromoly Pushrods This package will include the following items:
  • Your L99 camshaft of choice (Designed To Work With VVT Phaser & REQUIRE REMOVAL OF AFM LIFTERS)
  • PRC Double Spring Kit
  • Texas Speed Hardened Chromoly Pushrods Camshaft Featuring TSP Lobe Profiles
  • Comp Cams Phaser Limiter Kit
Texas Speed is one of very few companies that is able to test & properly develop L99 camshafts using the camshaft phaser. As a result it's very important that we do not release the entire specs of each L99 camshaft. If you have additional questions about sizes & recommended use please give us a call!!
These TSP L99 camshafts are custom designed for applications where the AFM lifters are being removed. By removing the AFM Lifters we are able to run lobes similar to what the LS-3 engines run. The result is approximately 15 extra horsepower compared to the AFM friendly lobes!!
All L99 TSP camshafts require the use of the Comp Cams Phaser kit (included in L99 Cam Packages)
If you are going to run our TSP VVT camshaft without AFM, you will need the AFM/DOD delete kit. This kit will include an LS3 timing chain dampener, 8 new LS7 lifters, LS3 lifter trays, GM LS3 cylinder head gaskets, GM LS3 cylinder head bolts, LS2 valley cover, PCV hose, PCV plug, and a TSP camshaft swap bolt and gasket it. You can replace all 16 lifters with new GM LS7 lifters for an additional $70!
this is what I was looking at. dont reall have specks
Old 10-21-2011, 06:29 PM   #7
mgoodbar
Drives: 2010 L99
IDK if TED has a email tune for one of these cams???
Old 10-22-2011, 01:55 AM   #8
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
On TSP's website it says mid 220's int.duration, nothing about exh. Duration, 620ish lift and you should use an after market converter.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 10-22-2011, 02:27 AM   #9
kaler
kaler's Avatar
Also you need to send the ECM to TSP for the cam phasing tables before you drive it,included when you purchase a VVT cam from TSP. After that it is tuned just like any other LS engine. Do your self a favor and call TSP and talk to Jason he will be able to point you in the right direction.
Old 10-22-2011, 09:30 AM   #10
mgoodbar
Drives: 2010 L99
ok thanks guys, Sorry I did not see the specks. duuu.. lol... ok I will give hime a call tuesday... guess its gona be a VVT 1 cam though.. i dont want a stall. I drive the car to much for that... 110 miles a day 4 days a week.... hate to say it but im gona have to get a gas saver to keep miles of my baby... thanks agin guy's
Old 10-22-2011, 10:05 AM   #11
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
If he is getting a VVT cam then it would be an auto(L99) since the manual's(LS3) do not come with VVT. I had the Mast Stage II VVT cam installed last year.
It has the following specs.
224/238 .578/.593 115 LSA
If you get the VVT cam from TSP they provide a tune for it. You will need the DOD delete kit and phaser limiter to run it. You may also want to upgrade the springs while you are at it.
I just had the VVT cam taken out and replaced with a LS3 style that is more friendly with the turbo. I will be selling the Mast VVT cam along with the Comp phaser limiter if you are interested.
I know I had posted a video on here. I will look for it so you can hear what it sounds like but I can tell you it is not too choppy.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 10-22-2011, 11:44 AM   #12
mgoodbar
Drives: 2010 L99
yea I was gona do springs and the whole 9 yards wile i was there.. cool they give ya a tune..
did you have to run a stall with it? with those specks it looks like it could benifit from one... about a 2800-3200
pm me a price, but idk if i will have the funds... was gona start buying stuff with income tax...
Old 10-22-2011, 12:04 PM   #13
SRT10KLLR
Yes, it has a ProTorque 3000. The new built Circle D 6L80 will be going in along with here tq converter so the ProTorque will be for sale too.
Old 10-22-2011, 01:27 PM   #14
siriusdish
Drives: 2010 Camaro L99
question???
With the VVT3 Cam from TSP is there a paper that helps the tuner or is there a Disc???
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
VVT Cam .......... or ......... LS3 Conversion PQ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 181 12-10-2011 01:01 AM
Another cam question gatorlover Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 08-02-2011 01:15 PM
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain robertway Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 02-21-2011 09:38 PM
LS3 cam question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 05-04-2010 05:41 PM
Cam gear question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-16-2010 07:01 PM
