Where to start with pc polisher
Ok so I now have bought a PC polisher and adams products, I know I need to do the two bucket wash and clay the car first. Question is this the car is only three month old and does have some fine swirls caused from my ignorance prior to learning proper car washing techniques. the question is should I start off with the Adams Swirl and Haze remover or try the fine polish first to see if it gets the swirls out and move to the swirl and Haze if the polish doesn't correct the swirls. I appreciate any help.
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
If you can see the swirls.....start with the SHR asnd then progress to the FMP
More human than human
It's usually best to start with the less agressive polish. do one spot, and if that does not take it out, then move to the more aggressive polish.
![]() 1100 - 10/22/2008 3000 - 05/27/2009 3300 - 06/06/2009 3800 - 06/29/2009 4B00 - 06/29/2009 Warehouse 13 survivor Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my mind. |
This is correct. Try FMP first. If it works, great. If not, step up to SHR and finish with FMP
[B]
![]() ![]() ![]() ![]() Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS Join Date: Oct 2011
+2
#6 | |
Drives: The shiny ones. Join Date: Mar 2010
And just test in a 2'x2' section to start and figure out what you'll need to do to get the desired end result. Once you figure out what it will take, then proceed around the whole car. |
#7 |
Voice Of The Voiceless
+4
#8 |
so I would guess that I could also use swirl and haze remover on the hood, roof and trunk if needed and start with machine fine polish on the sides of the car since the sides have fewer and finer swirls. is this correct
#9 | |
Never assume you know what products are going to be needed to correct the swirls. At best, with experience, you'll be able to make an educated guess, but thats about it. Test first, then decide on what to use. The swirls are going to be fairly consistent over the entire vehicle, its just typically more obvious on areas like the hood and deck lid b/c thats where the sun and light most commonly show them. Its not often you get direct, high intensity light, coming in from the side. Select a 2'x2' section on your hood to start, go with just the FMP and see what the results are. If that fixes it, then you have your answer for the rest of the car. If it doesn't then go at another test spot with SHR followed by FMP. Remove the residue and inspect. If that fixes it then you have your answer for the rest of the car. |
#10 |
got it now appreciate the help
#11 | |
"Detailing Devil Dog"
Drives: 2001 Corvette Coupe Join Date: Jan 2010
"Marines - Making the other guy die for his country for over 200 years."
#12 | |
![]() Drives: Camaro 2Lt Join Date: Nov 2011
#13 |
![]() Drives: 2012 Camaro 2SS -- 02 Escalade Join Date: Apr 2011
best place to start is on a different car altogether.....like the wife's.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro LS Join Date: Sep 2008
Do I need to remove the product in between the steps? Like remove the SHR before doing FMP? Or can I get away with going over the products and just removing at the end after the Sealant?
SS sometimes hesitant to start? "Open, then close drivers window"? What's wrong? | Yellow Camaro | 5th Gen Camaro SS LS LT General Discussions | 10 | 02-24-2017 10:54 AM |
hard to start, when warm? | buelldude | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 52 | 07-26-2016 04:46 PM |
Remote Start on Manual Transmission | Dentyneice | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 51 | 02-11-2015 01:56 PM |
Remote Start on an M6 | djb525 | 5th Gen Camaro SS LS LT General Discussions | 65 | 12-23-2013 10:47 AM |
Rough Engine Start After Tune? | Tanner | Tuning / Diagnostics -- engine and transmission | 9 | 10-08-2009 12:25 PM |
