Old 01-22-2012, 04:54 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Guys with headers... first of many header questions.
I just ordered my catted 1 7/8 kooks long tubes Friday. What are you guys doing about the plugs and wires?... are the stock ones fine? should the plugs be regapped?
As for wires... I know there are many brands, but is there one you guys would recommend more than the other?
Thanks
newagemuscle is offline   Reply With Quote
Old 01-22-2012, 05:03 PM   #2
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Stock plug wires are normally okay with Kooks. No need to play with the plugs. Aftermarket wires will give more clearance, and look better. I used to run MSD on everything, but lately, I have found the Taylor Thundervolts have a better design fit better, and don't require bending the boot like MSD.
MarylandSpeed is offline   Reply With Quote
Old 01-22-2012, 05:07 PM   #3
newagemuscle
Philippians 4:13
Thanks... I'll have to look into those. Is that something you guys sell?
Old 01-22-2012, 05:08 PM   #4
MarylandSpeed
Here you go-
http://marylandspeed.com/engine-comp...1249_1252.html
Old 01-22-2012, 05:11 PM   #5
newagemuscle
Philippians 4:13
Sweet... they would'nt happen to make them in yellow... would they?
Old 01-22-2012, 06:21 PM   #6
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Thanks
I've been running the stock plugs and wires with Kooks 1 7/8 headers for over 2 years with no issues. My car also runs like a bat out of hell.
Old 01-22-2012, 06:34 PM   #7
newagemuscle
Philippians 4:13
I guess the wires would be more of a looks thing... then again I can't remember if you can even see them with the engine cover. My car has been in storage the past 5 months, so I have not looked at it in a while. Do you have your kooks coated?
Old 01-22-2012, 06:57 PM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
Check out Padre's build thread. Wires aren't just for looks.
Click to view my build thread
Old 01-22-2012, 07:04 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
For those basic bolt-ons the stock wires are just fine. You really don't see them with the engine cover on. Personally, I wouldn't speend the money on those for now.
As for coating.....I have it and definatley recommend it if you want your headers to look nice and pretty for a long time. If you're even remotely on the fence about it, do them now before you put them on. It's alot easier to do them now rather than decide later you don't like the looks of them un-coated (they'll turn a purplish/yellow color) and then have take them off again and send them to get coated.
Build Journal
Old 01-22-2012, 07:10 PM   #10
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
+1 on the Jet-Hot ceramic coating
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 01-22-2012, 07:43 PM   #11
SmokinBills 2SS
SmokinBills 2SS's Avatar
Drives: 2SS Cammed up, Clear Bra, Clean
Kooks and MSD w/Taylor boots,Katech relocators,Corvette fuel line,stock fuel rails rotated,GMperfomance valve covers
SmokinBills 2SS is offline   Reply With Quote
Old 01-22-2012, 07:53 PM   #12
Big Top Gt
Drives: IOM 2010 2SS/RS (LS3)
Send a message via AIM to Big Top Gt Send a message via Skype™ to Big Top Gt
Aren't the Kooks stainless?
I've got a seton order and didn't think the coating was necessary.
Big Top Gt is offline   Reply With Quote
Old 01-22-2012, 08:06 PM   #13
caverman
caverman's Avatar
For looks.....it is necessary.
Here is a set of used ARH (but any Stainless 304 will do the same) before and then after coating. Once they are coated they will maintain that look for a very long time.
Build Journal
Old 01-22-2012, 08:28 PM   #14
kennyo
kennyo's Avatar
Drives: 2017 2SS Hyper Blue
You can't really see these things unless you jack the car up,correct?
Mods-Corsa Extreme Axleback
kennyo is offline   Reply With Quote
Couple header questions.. ZachSGMSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 09-01-2011 03:36 AM
newb exhaust questions... need headers, and catback. chrisprater Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-28-2011 11:15 PM
A few questions about cams, headers and exhaust. Oxtar41 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 09-15-2010 08:11 PM
Running Thread: Header Install Questions Captain McFunk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 09-12-2010 01:10 AM
Header Questions Missile Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-27-2009 07:37 PM
