![]() Drives: 2011 Cyber Gray 2SS 6 speed Join Date: Jan 2012
Jacking points
I am not clear on the correct jacking points on this car. I know it does not come with a jack, but you need to be able to jack it up.
Last week I did jack it up to pull the wheels off to install splash guards, but I was guessing at where to place the jack. For the rear, I used my aluminum racing jack and placed a small piece of wood on the jack puck and lifted in front of the rear tire on the frame rail. But I could not see a frame rail in the front..so I switched to my truck's hand jack and found what looked like a cut out in the plastic rocker and jacked behind the front tire in that cut out. ALso wondering if I take my car to a garage and they have the scissors type hydraulic lift, where do I tell them to position the blades? I might put a small red dot on the jack ponts once I am convinced I know where they are. Thanks, Bob |
Formerly Camaroc5
Drives: 2010 Camaro LT/RS M6 Join Date: May 2010
thank you
Formerly Camaroc5
![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 M6 Join Date: Sep 2010
Very nice! I just logged in to search this and luckily i found it at the top of the list. I am jacking up my car tomorrow to remove my brake calipers. The car will sit on jack stands until they are done. Having Mike powder coat them.
#6 |
![]() Drives: 2016 Siliverado LT. Camaro SS Join Date: Jul 2009
Thank you, I always wondered where you put the jack's and jack stands.
Just Cruising!
USN - 1990 - 1994 2010 Camaro 2SS Red Jewel |
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
...with four jackstands, please be level and be careful... |
#8 |
![]() ![]() ![]() Drives: 2011 Coupe, 1LT, A6, No RS Package. Join Date: May 2011
Looks like GraySS2011 was right about the cut out in the plastic for the jack. Thank you camaroc5 for the picture as well.
It's obviously important to know where to put the jack, excellent and informative post.
Never Underestimate The Power of Forums
#9 |
For the rear end I use the lower control arms and for the front end I use the frame.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
#10 |
Thanks for the pics now I know where to place the jack stands when I raise the rear.
#11 |
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
in the rear i raise the whole rearend by the diff MOUNT.
#12 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
Awesome pics!
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
So looking at the pics if you need to raise the vehicle by the "Scissor Jack Points" does one need the "adapter pucks" like I've seen for Vettes and unibody cars in general?
#14 |
disco kryptonite
you can get points for that?!?
edit: oh, nevemind... the title threw me off, i thought this thread was about something else.
| Gear shift points in 2011 LS | skcamaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 22 | 03-12-2012 12:27 PM |
| 12 points from license for speeding | Pain505 | General Automotive + Other Cars Discussion | 127 | 01-10-2012 07:06 PM |
| 6 speedauto: easiest way to change shift points | chevy454 | Tuning / Diagnostics -- engine and transmission | 4 | 08-15-2011 06:24 PM |
| Location points for "Timing " Bushing | bee sting | Suspension / Brakes / Chassis | 8 | 05-31-2011 09:57 PM |
