Old 03-28-2012, 03:22 PM   #1
alanp
Drives: 2012 !SS
Evans waterless coolant...?
Seems like a slick idea & "life of the engine" product that never needs to be topped off or changed. Seeing that our motors are aluminum and prone to damage by water/coolant blends this looks like a good long term way to go.
Anyone out there try the stuff?
http://www.evanscooling.com/products/coolants/
alanp is offline   Reply With Quote
Old 03-28-2012, 04:25 PM   #2
HDRDTD
What are the odds that if you changed to the Evans coolant, that GM would void your cooling system warranty?
Old 03-28-2012, 05:04 PM   #3
BigCarrot
xbox: this is tedious
BigCarrot's Avatar
Drives: 2011 1SS M6 Camaro IOM
http://www.evanscooling.com/products...y-information/
There's some neat info about warranty right on their site
Big Carrot's Changes - It's a work in progress
Originally Posted by Fiftydriver View Post
Seems like just yesterday I spent $450 for a Roto Fab CAI!!! What the hell happened.
BigCarrot is offline   Reply With Quote
Old 03-28-2012, 05:22 PM   #4
Silverlsinva
Silverlsinva's Avatar
Drives: 2013 Fiat 500 Abarth Grigio
Hmmn interesting might have to try this.
Silverlsinva is offline   Reply With Quote
Old 03-28-2012, 05:23 PM   #5
HondaPowered
HondaPowered's Avatar
Drives: '09 Honda Civic LX
I would avoid it
Saving up for a camaro.
Dream camaro is either a 1/2SS with RS, black with red stripes, or red with white stripes.
No rice with my order.
HondaPowered is offline   Reply With Quote
Old 03-28-2012, 05:28 PM   #6
turbostang7
turbostang7's Avatar
Drives: 2012 45th 2ss
We tried this in some equipment at my last job, it actually made them run cooler! Nothing else done to them just the swap. If this helps anyone who is thinking about trying it. Been in my duramax for 2 years no issues so far
Sent from my DROIDX
turbostang7 is offline   Reply With Quote
Old 03-28-2012, 07:37 PM   #7
Butcher
Drives: '03 MY/MR Z06, '09 Sliver/Red G8 GT
I use it in my race car, it works good. However, there is a "catch". There can't be any water in the system at all. You have to thoroughly flush the system, otherwise it isn't any better than regular coolant.
Butcher is offline   Reply With Quote
Old 03-28-2012, 11:37 PM   #8
Nessal
Drives: Exige, Miata, Ghia
Hmmm this is interesting....but how is it possible to get every drop of water out?
Nessal is offline   Reply With Quote
Old 03-29-2012, 12:15 AM   #9
NavyDood
Retired Navy
Drives: 2010 2SS/RS
They have a flush to use before adding their coolant. http://www.evanscooling.com/products/coolants/prep-fluid/
NavyDood is offline   Reply With Quote
Old 03-29-2012, 11:09 AM   #10
alanp
Drives: 2012 !SS
I also heard it made the motor run cooler...thanks for the reply's.
Old 03-29-2012, 11:16 AM   #11
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Uhmm... Hmmm
I don't know what to think of this...
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 03-29-2012, 04:35 PM   #12
Nessal
I have witness first hand the corrosion that is caused by water based coolant. In one of my previous car with an iron block, I did a complete flush and installed a new radiator. There was so much orange gunk which I believe would be iron oxide (rust) in every nook and cranny that it is impossible to get it all clean....ever....the car only had 100k miles on it.
Old 03-31-2012, 11:58 AM   #13
NavyDood
Retired Navy
Drives: 2010 2SS/RS
I'm not totally up to speed on the Evans Waterless coolant. From the readings I have done the up front cost is much higher, but the people that have switched had nothing bad to say.
Old 03-31-2012, 12:07 PM   #14
v8
v8's Avatar
Drives: 19 Z06
Sounds interesting, I will check out the website
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 11 04-08-2020 11:49 PM
Coolant Level LimaCharlie Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 4 09-09-2012 09:38 AM
LUCAS SUPER COOLANT ADDITIVE TEMP & DYNO TESTS Matt@KB Forced Induction - V8 19 03-14-2012 02:51 PM
Coolant Reservior Boil Over Via the Evac Hose? TheHorse13 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 08-27-2011 10:38 AM
Need help finding source of coolant leak Swoop Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 02-18-2010 09:08 PM
