Old 04-11-2012, 12:32 AM   #1
ewoolsey
Drives: Victory Red 2011 Camaro SS/RS
Exclamation Installing headers problems
Alright so i just finished installing my obx headers last night on my ls3 camaro and here are some problems I had. Any help is appreciated.
1. a loud noise when I back off the throttle at above 4000 rpm. its pretty loud and its a funny sound. don't know how to describe it. is it normal with headers?
2. rattle/bonking noise coming from the back. kinda sounds like the exhaust is bouncing up whenever my car hits a bump? where should i look to fix this?
3. When i took out my pre cat 02 sensor the threads like tore off? so installed it with a spark plug anti fouler. is that a problem? also is it bad to drive the car with neither of the pre cat 02 sensors plugged in? my extensions havnt come yet. thanks guys!
ewoolsey is offline   Reply With Quote
Old 04-11-2012, 12:38 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
1. Doesn't sound normal. Mine doesn't do that at all. Either a better description of the sound or maybe capture it on video for us?
2. My guess is that your cat-back is hitting the cross brace. You need to check to make sure there is clearance with your cross brace. If not you need to adjust your exhaust some and/or add some spacers to the cross brace.
3. WOW...I can't imagine the car would run good at all without the pre-cat sensors. That's what the computer uses to adjust fuel trims. IDK...personally I would really limit my driving with out the front O2 sensors. I definately wouldn't be hammering it until you get your O2 sensors back in.
Sounds like you're going to need to stop by a dealer and get a replacement O2 sensor for the one that's stripped out. That's not an uncommon thing
Build Journal
Old 04-11-2012, 12:48 AM   #3
Avenging Orange
Avenging Orange's Avatar
The sound, I'm quessing a chirping squeedgy sound, is prob what I had. Leaky manifold gasket. Make sure the gaskets are installed correctly. You should be using the factory gaskets. (they can b tricky). I had to replace the drivers side.
You'll need to push the cat back up as far as possible (I used a tire jack), then tighten down the clamps then the cats/off road pipe. It'll stay put then.
No, It is not good to run without front 02. Do not drive it till you replace it.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-11-2012, 02:22 AM   #4
ewoolsey
shit i didn't know it was bad to drive it like that... i guess ill stop haha. is the exhaust not supposed to rest on the cross brace? i didn't really look i guess. and i bought new gaskets when i replaced them but it doesn't sound like their are any leeks at idle?
Old 04-11-2012, 03:41 AM   #5
gelboy1015
Drives: '10 2SS/RS, MKIII Supras
Yea, dont let the exhaust rest on the cross brace. There was a member on here who kept having problems with the knock sensors freaking out everytime he hit a bump because their readings were being thrown off from the vibration.
gelboy1015 is offline   Reply With Quote
Old 04-11-2012, 04:29 AM   #6
Corvette-camaro
Drives: Camaro 2010 auto trans
I had the second problem as urs , it's common , u just need to do an alignment for the cat-back and add some spacers for the cross brace to make it lower a bit.
Corvette-camaro is offline   Reply With Quote
Old 04-11-2012, 01:37 PM   #7
ewoolsey
Wow thanks guys. I love this forum. Everyone's great. I'll make sure to fix it. Any more help on the other problems will be great
Old 04-11-2012, 01:39 PM   #8
ewoolsey
Could the Loud sound when I back off the throttle be because the o2 sensors aren't installed and its running bad?
Old 04-11-2012, 02:55 PM   #9
caverman
caverman's Avatar
I guess it's possible. Install the front O2 sensors and find out.
Personally I think you should not drive the car without the front O2 sensors. If you absolutley have to then be slow and carefull about it. No WOT runs or anything.
Build Journal
Old 04-11-2012, 03:16 PM   #10
ewoolsey
shit i was driving kinda hard for a day... do you think i did any damage? it seems fine still. strange thing is it was running really well. had lots of power the whole way through. it was way faster than before.
Old 04-11-2012, 04:48 PM   #11
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
It doesn't really matter since whatever is done is done. Stay off of it until you get the O2s installed. You should tune as well.
The noise you are describing, is it a sound kind of like the opposite of going WOT (eg, kind of sounds like the car is breathing backwards - I realize this sounds kind of wonky). The coast down loudness from high rpms is normal with long tubes.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 04-11-2012, 05:34 PM   #12
caverman
caverman's Avatar
I honestly don't know how the computer would handle not having the O2 sensor. Since it's running okay my guess would be that it kept the Fuel Trims at the same level that was set the last time you had the O2 sensor it. It probably just can't make any ajustments with it out. Might explain why it's still running okay.
If that's the case then it would probably be okay to drive it but I don't know that I would chance it much. After all if it did happen to go too lean for some reason and burnt a piston then you're out a motor. If it runs too rich it will just run like crap and probably put out some nice black smoke out of the exhaust.
Just try to get some O2 sensors in there ASAP.
Build Journal
Old 04-11-2012, 06:27 PM   #13
ewoolsey
Geox tigers that's exactly the sound I'm talking about. So that normal then? Good to hear! Also if it is running to lean will the engine temp go up?
Old 04-11-2012, 08:35 PM   #14
geaux_tigerss
Lean will destroy a motor. Part of the fuel injection is quenching heat in the combustion chamber via fuel evaporation. Heat leads to many horrible things.
I think that WOT runs rely on the MAF whereas long term corrections rely on the O2s so you should be okay. I'd still be careful about it though.
Summit White
extensions, headers, noise, problem, sensor
installing headers this weekend.. jeffny09 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 12 05-20-2011 11:34 PM
question on installing headers. jeffny09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-20-2011 10:30 PM
Couple of questions installing ARH headers Jeffro19 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-02-2010 10:01 AM
installing headers in driveway - which jacks/ramps?? AdamCzap Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 04-28-2010 02:42 PM
Installing headers using ramps? Camar0wn3d Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 10-18-2009 04:41 PM
