Old 01-20-2010, 02:14 AM   #1
Black LS3
Black LS3's Avatar
Drives: 2010 Black 2SS LS3
Lightbulb * Muffler Delete * Has Anyone Reused Their Stock Chrome Tips Again?
Hey everyone,...
Well,... It's getting close.
I should be getting my 2SS here in the next 2 weeks to so and I want to start ordering parts and accessories to go with it.
I think I've made up my mind and I'm going flat out with the Muffler Delete Setup with the Magnaflow Tru-X 2.50 Inch X-Pipe with the Resonators Removed . Yeah Baby .
My question is,... Has anyone Re-Used their Factory Stock Chrome Tips that were on their Factory Mufflers and just Re-Welded them on to the Replacement Straight Pipe?
Or,.. Do I need to Order 2 New Ones?
Whats the Widest Tip that will Fit in those Exhaust Port Holes? 5 Inch Chrome Tips?
How much room is there to cut those tips off?
Do you have ANY Tips (No Pun Intended) or Suggestions for me before it comes time to Start Cutting those Tips off of the Stock Mufflers?
I'm not the one that'll be doing it. As always and with my other vehicles,... I'll be having my friends down at a local muffler shop do the install for me so someone who actually knows what they're doing will be performing this operation for me.
So Please,... Any Help from you guys that have already done this will be appreciated very much.
Black LS3
A.K.A. Jim
OnlineAutorama.US - A Camaro Parts/Accessories Site for Dealers & Vendors.
Muffler Delete. ( See Videos - Vid 1. - Vid 2. )
Stock Resonators & H-Pipe Removed.
Magnaflow 2.50" Tru-X X-Pipe.
AirAid Cold Air Intake System.
11.21.09 1100 Order Accepted At Dealer - 11.24.09 2000 Accepted At GM - 11.25.09 2500 Preferenced - 12.03.09 3000 Production Control Notes: 01/11/2010 - 12.17.09 3400 Order Broadcast - 01.13.10 3800 Order Produced VIN # 2G1FT1E - 01.25.10 4000 Available to Ship from Rail Yard by Truck - 01.27.10 5000 Delivered to the Dealership - 01-27-10 6000 Delivered to Customer.
Black LS3 is offline   Reply With Quote
Old 01-20-2010, 08:14 AM   #2
toehead93
Drives: 2014 2SS/1LE
Yes, I have seen many people post they have re-used their stock tips.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 01-20-2010, 09:44 AM   #3
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
+1
I had the mufflers removed, and my H-Pipe replaced with an X-Pipe. I left the resonators on (they're pretty small on the LS3), reused the stock tips, and it sounds amazing.
A good shop will have no problems cutting things properly and be able to re-weld them into place on the pipe that is going to replace the mufflers.
TommyTSquared is offline   Reply With Quote
Old 01-20-2010, 09:56 AM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
Hey Black....as a suggestion, if you don't use the resonated x-pipe like #11386 then you might leave your resonators on. You can always go back and take them off if it's to loud. Also...I would still suggest you call Jordan at JDP Motorsports and make sure he can't get you a better deal on the x-pipe. I would also just feel him out on his recommendations for your setup since he has sold and dealt with many of these.
Hey TSquared....which x-pipe did you use? Was it the Tru-X type or the muffler/resonated type?
Build Journal
Old 01-20-2010, 10:23 AM   #5
TommyTSquared
Drives: RSSS
I used the one that was suggested/offered in one of the other muffler delete threads. I think it was here. There was also a code for free shipping IIRC.
Old 01-20-2010, 11:05 AM   #6
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
The muffler shop guy had no problem cutting and welding the factory tips...definitely do-able and can save some cash.
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 01-20-2010, 12:22 PM   #7
sfgiantsfan9
Drives: Camaro 2SS/RS and 2001 Ford F250
Think removing the resonators would actually change the sound or the volume??
sfgiantsfan9 is offline   Reply With Quote
Old 01-20-2010, 12:26 PM   #8
68/2010
Emerald Coast Camaros
68/2010's Avatar
Drives: 2010 2SS Rally Yellow
Same here
Old 01-20-2010, 12:31 PM   #9
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
It will change both.
brandotron is offline   Reply With Quote
Old 01-20-2010, 04:01 PM   #10
sfgiantsfan9
How would it change? Particularly on the LS3 with the smaller mufflers? Getting muffler delete done and contemplating whether to leave the resonators on or take them off.
Old 01-20-2010, 05:34 PM   #11
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
take em off!! i wish i wouldve before i garaged it for the winter.
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 01-20-2010, 05:36 PM   #12
Partick
Partick's Avatar
Drives: 2010 Camaro 2SS
Originally Posted by 68/2010 View Post
Same here
+1
Partick is offline   Reply With Quote
Old 01-20-2010, 06:27 PM   #13
Eski7399
Arizona All Gens
Drives: 2SS/RS, M6, IO-Int
Reused mine. Also had them pushed out about an inch or so. You can actually see them now. Really adds to the look of the car.
Eski7399 is offline   Reply With Quote
Old 01-20-2010, 06:55 PM   #14
FLYNNZL1
Drives: Man
Send a message via ICQ to FLYNNZL1 Send a message via AIM to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
I reused mine also, looks great.
FLYNNZL1 is offline   Reply With Quote
Muffler delete complete... my observations. Spiffyguitar Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 33 07-13-2010 09:22 PM
Muffler Delete dr1ven Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 01-12-2010 12:52 PM
Muffler delete? chris rs ss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 11-28-2009 03:54 PM
Good tips for the MUFFLER DELETE? LDGn63 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 06-25-2009 10:48 PM
To muffler delete or not to delete BumbleBeeSS2009 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 81 06-25-2009 05:55 AM
