Old 06-14-2010, 02:59 PM   #1
jeffa55
Drives: 2010 1SS/RS Camaro 6M Cyber Grey
LT install questions
I had two questions that I cannot find answers to (I did a quick search)
1 - how high up does the car need to be to install headers from below? I have a set of ramps and am hoping that is high enough... maybe brings the car up about 10" or so. I am putting in a new ARH LT system
2 - What size is the O2 sensor socket? I have an old one I used from my Acura and didn't know if it was the right size.
3 - Any special tools I should be SURE to have before the install?
Thanks!
jeffa55 is offline   Reply With Quote
Old 06-14-2010, 03:09 PM   #2
Silver Ice Man
Silver Ice Man's Avatar
Drives: 2014 2SS/RS Spring limited edition
Thanks!
Here I think this should help out a little.
Not sure on the hight though, best of luck.
I will be doing a set of the Dynatech LT's very soon, so I have been brushing up on what I am about to get into.
http://www.planetlsx.com/tech/How_To...0_Camaro_SS/98
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor.....
MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow....
Silver Ice Man is offline   Reply With Quote
Old 06-14-2010, 03:15 PM   #3
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
Drive up ramps wont be high enough especially if your doing midpipes. it will be VERY straining. I've done 2 sets and i'll tell you you need about 18 inches of height, front and rear 18" height is best if you cant get more. This is a very easy and straight forward install. if your o2 wrench isnt the right size, im sure you will have an open end wrench that will do the job.
happy modding!
Zach
The 2010 Sin is offline   Reply With Quote
Old 06-14-2010, 03:32 PM   #4
jeffa55
Thanks for the info. When you say it needs to be up 18" is that 18" higher than it sits or does the underside of the car need to be 18" off the ground? If the ramps are 12" and the car's underside is already 5" off the ground it will be at 17"... just want to make sure i have it right.
Thanks
Old 06-14-2010, 03:44 PM   #5
RedJewelSS
RedJewelSS's Avatar
Drives: six in a row makes it go
Thanks
brian
2010 camaro SS. LS3/6SPD (sold)
2003 Jeep Wrangler/Rubicon/NV3550
1989 F-150 4x4/300 I6/M5ODR2
1982 mustang. 351W/414stroker C4 9" rear. bracket racer
1977 F-100 5.9L 12V Cummins conversion/NV5600
RedJewelSS is offline   Reply With Quote
Old 06-14-2010, 04:32 PM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I did mine on jack stands. You just need to get the car up as high as you can and make life easy. The install is pretty easy though so if you have stands I recommend you use them.
MODS:
Old 06-15-2010, 02:27 AM   #7
Ivan @ Southwest Speed
Check out my install/review.
http://www.camaro5.com/forums/showth...stall%2Freview
Three hours, 4 handtools, no cutting, easy day.
I used a total of 6 jackstands to be safe since it was the first time using the handjack on the car.
Enjoy and let us know how it comes out!
Ivan
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
BBK LT Install (PICS) WHIPPLECHARGED Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 167 04-21-2012 04:46 PM
LT header install toehead93 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 05-26-2010 02:35 PM
Afterburner kit install questions chrislhardin 5th Gen Camaro SS LS LT General Discussions 18 04-26-2010 02:30 PM
Cam install questions Fritostud Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 03-22-2010 01:47 PM
