![]() ![]() Drives: 2006 White Corvette Convertible Join Date: Feb 2010
Injen CAI Window Washer Reservoir Bottle Issue
I hooked up my Injen CAI tonight and tooled around town a little bit to test it out (it works, btw).
When I got back, I started putting my car completely back together. This included putting mats and stuff back in the trunk and adding window wiper fluid. Everything looked good until the fluid started leaking out of the bottom of the reservoir. I knew exactly why, though. When I was assembling the reservoir earlier, I noticed the black, rubber, reservoir pump grommet just sat in the hole in the Injen Reservoir instead of fitting snug like in the OEM, stock reservoir. So that's why it was leaking. Did anyone else have this issue? Or did I just get a faulty part where they drilled the hole too big? If you've installed an Injen CAI, let me know.
The Corvette is an animal.
I hear what you are saying............I am gonna head to work in an hour, let me take a look and see how the grommet is on my bottle.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
Mine fit fine. No leaks.
Tampa Gulf Coast Family
Drives: 2010 Camaro 2LT/RS Black on Black Join Date: Apr 2010
Mine was fine too. I'm guessing you didn't push it all the way down. Mine looked like it was in but when I looked closer to make sure I noticed it was close but I had to push it a few more times..
Winners find a way
Drives: 2010 2LT/RS M6 Join Date: Jun 2010
my grommet fit fine, it was tough to push all the way in.
#6 |
I am ok.......mine's snug, but the pump is leaning out a bit. I figured that was normal.
Formerly owner of:
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
I haven't put new fluid in mine yet. Lol. I'll have to check it out.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
No leaks here, and the pump does have a bit of lean to it. Make sure you pushed the grommet in all the way, just to be sure.
#9 |
Whats a Millwright?
yeah pump does lean. I had to push it twice to be sure but is leak free.
#10 |
OK. I'm going to call Injen, because mine sits in that hole and I can move it around. The Injen reservoir hole is to big. Thanks, fellas.
#11 |
I just called AutoAnything and explained. They called Injen and called me back. The new reservoir is on the way. Weird issue, but should be solved soon.
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2LT 334HP Join Date: Feb 2010
Thats cool. Glad you got it worked out. Auto Anything's customer service is second to none. Let us know how the new one turns out.
#13 |
Just finished installing my Injen, was able to do it without taking the tire off by turning the wheels all the way to the left. On the issue with the grommet hole on the water bottle, the grommet was loose fitting but when I put the pump on it tightened up and was able to snap the pump into the bottle, so far no leaks. It's late will take it out tomorrow and also post some pics.
#14 | |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
| Tags |
| cai, fluid, injen, leak, reservoir |
| Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
| Window Indexing issue getting worse in cold weather. | Rogue Leader | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 02-15-2010 11:53 PM |
| Window issue | smhss | 5th Gen Camaro SS LS LT General Discussions | 1 | 02-10-2010 11:49 PM |
| HELP, CAI and Birthday Issue!! | Scott@Bjorn3D | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 02-09-2010 06:43 PM |
| CAI issue | DanD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 07-05-2009 07:40 AM |
