Old 07-06-2010, 11:43 PM   #1
67ponycar
67ponycar's Avatar
Drives: 2010 Synergy Camaro
Send a message via Yahoo to 67ponycar
Busted Door Window (due to sun / heat & high humidity)
Hi Y'all,
just wonder if someone of you guys had that issue also?!
My car was exposed the first time for a longer periode to the sun (usually it stays in a garage and has only 400 miles on it - I got it 3 weeks ago)
... as this happend approx. 2pm on July 4th in Tuscaloosa, AL.
The window busted towards the outside and was basically just holding together with its tinting foil. The V-shaped gap at the B-pillar was approx. a 1/2 inch wide.
The day after (on Monday) I went to my GM dealer and complained about it, but the service manager told me, he never had that issue before, and that I should report it to my insurancewhich I refused to do.
After my conversation with him, I went to the sales manager and told him about my window, and he told me, that they just had 2 other GM vehicles on their lot with the same issue on door windows (without tinting foil).
So, to me it seems like an supplier issue ...they might have an issue in their glas tempering process
I would appreciate any report of similar issues.
Thx
Martin
67ponycar is offline   Reply With Quote
Old 07-06-2010, 11:48 PM   #2
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
Wow that's the first I've ever heard of a door window breaking from a temperature change.
Sterling is offline   Reply With Quote
Old 07-06-2010, 11:50 PM   #3
motorhead
Wow that is really odd. Never saw that before. Looks to me like maybe the window went up to far or the indexing didn't drop the window down before the door was opened. Heat you say, that's different. Either way I would make them fix it. It wouldn't be bowed out if someone hit it. Has to be some type of defect. Good luck.
Old 07-07-2010, 12:04 AM   #4
Russo
Unofficial Glass Tech
Russo's Avatar
Drives: 2014 Ford F150 FX2
Send a message via Yahoo to Russo
doubt the heat broke the window... unless it got over 1200 degrees... my guess is that while the glass was hot, something hit it which is very possible
Russo is offline   Reply With Quote
Old 07-07-2010, 12:07 AM   #5
67ponycar
67ponycar's Avatar
...ohh, maybe i should also say, that the car was sitting there since 7am with all Windows up and did not get moved/touched anymore.
Actually we have been sitting in the carage and in carport as it happend and we could hear it bust.
First of all, we wondered what it was, till someone pointed out the Camaro window.
Old 07-07-2010, 12:07 AM   #6
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
something hit it and it's bowed OUT??
Toasty is offline   Reply With Quote
Old 07-07-2010, 12:13 AM   #7
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Looks like an inside job to me! could not help it.Sorry to hear.Seems that the dealer would replace it seeing how there was indication of impact?Every time I open my drivers door I look for the window to index down.Almost if expecting it not to sometime.Need to get over it I guess.I hope the dealer changes their tune and replaces it under warranty.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 07-07-2010, 12:15 AM   #8
Russo
Russo's Avatar
of course, if he opened the drivers door then closed it, the air would push the broken window out... not to mention the fact that it's wider than it is tall, has tint on it, and cannot physically bow in... i see it alot
Old 07-07-2010, 12:16 AM   #9
67ponycar
67ponycar's Avatar
...this side was parked towards the house wall, the only thing we have there is a flower bush ...and the only thing jumping around are squirls.
But we had issues like this at Mercedes with Prototype parts... and after researches it was always a window treatment issue during pruduction of the window.
Anyhow, it's now with the dealer, and I hope they fix it nicely without any further damages...
Old 07-07-2010, 12:23 AM   #10
67ponycar
67ponycar's Avatar
...hello guys, come on, give me a break! ...the car was parked...and as a german fellow I'm always locking my cars ..even in my driveway ...it was sittting there next to the BMW till 7am ...never got touched, nor moved, nor opend or what ever...
It just happend without being anybody close...
AND: The dealer had the same issue on 2 further new vehicles on its lot, evenso no Camaros.
Old 07-07-2010, 12:28 AM   #11
Russo
Russo's Avatar
gotta watch those squirrels... if you don't keep the feeders full, they'll throw rocks
Old 07-07-2010, 12:35 AM   #12
67ponycar
67ponycar's Avatar
nutbusters..but damn, they could have done this to our old Passat ...Kreuzteufelnochmal
Save Our Earth ...go GREEN
Old 07-07-2010, 01:04 AM   #13
jmaryt
Drives: 2010 cgm LS
isn't that fartvanugen!.,or some such?..it's like "fubar" not found in any "german" dictionary!
jmaryt is offline   Reply With Quote
Old 07-07-2010, 08:33 AM   #14
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Odd heat would do that I mean my car is outside from 7:45am until 6:15pm M-F temps ranging from 70 to high 90's in the hot Florida summer heat and humidity (A/C on from 7am to 7:45, and then again from 5:00om to 6:15pm)
Sean
#TeamBeckyD
**FIFTY HBM 2SS VERT**
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! AJ@ECSMotorsports Transmission / Driveline 21 11-13-2010 04:58 PM
Warning indicator: A/C off due to high engine temp NicksVSix Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-04-2010 03:44 PM
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 01:13 PM
Effects of Heat & Humidity 97one Dragstrip and Launch Techniques Discussion 13 08-26-2009 07:48 PM
