Old 08-11-2010, 01:27 PM   #1
N3WM4N21
N3WM4N21's Avatar
Drives: 2010 Camaro 2SS/RS
spark plugs
in everyones opinion what are the best performance spark plugs to get? and do the spak plug wires do anything for performance?
N3WM4N21 is offline   Reply With Quote
Old 08-11-2010, 01:32 PM   #2
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
the best ones believe it or not are the OEM plugs.
they are iridium plugs from AC Delco and are gapped properly. and NO changing the wires does nothing but change the aesthetics.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 08-11-2010, 01:32 PM   #3
Russell James
Russell James's Avatar
What came in the car works perfect unless your using huge boost or a big nitrous shot, then a cooler plug would be ideal.
Old 08-11-2010, 01:34 PM   #4
N3WM4N21
N3WM4N21's Avatar
So if i dont run boost or have nitous then plugs wouldnt do anything for performance?
Old 08-11-2010, 02:20 PM   #5
Russell James
correct
Old 08-11-2010, 09:14 PM   #6
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
If anything plugs and wires will hurt your performance. The stock stuff is great and will most likely last over a 100k miles.
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 08-12-2010, 08:28 AM   #7
JS
JS's Avatar
Drives: 2010 Camaro SS
Stock wires are very good but there are better alternatives as u increase power..
Iriduims OE plug is very good and can be run for most setups, but will not last 100K
If your going higher CR, FI or N20 talk to the shop that you trust and and ask their opinion.
I have used iridium in some setups and copper in others, most will use NGK, DENSO or AUTOLITE.
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 08-12-2010, 09:04 AM   #8
JANNETTYRACING
JANNETTYRACING's Avatar
This is a Cool Subject, As we the consumers are Bombarded with adds that special spark plugs increase performance.
We hear it so much we start to believe it, and go out and spend 50.00 on the new fangeled spark plugs only to find out the car runs exactly the same or worse.
In the case of the guy who never changed his plugs in 80,000 miles he will say WoW my car runs so much smoother with these special spark plugs.
OEM manufacturers Know for absolute certainty which spark plugs work best in there engines, the probably spend a cool Million in testing to find out.
I have always followed manufacturers recommendations for plugs unless the engine combination is drastically changed then it is off to the dyno with boxes of plugs to test test test still starting with the stock spark plug and moving to a heat range colder or hotter depending.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-12-2010, 10:05 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Ted.
All the while KNOWING those cheap ass copper NGK's, in a lower heat range, are going to be the winner.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-12-2010, 10:23 AM   #10
JANNETTYRACING
Quite the contrary, I had a 10 Camaro come in for a dyno tune last week that had the cheap ass copper NGKs in it, ( because a shop recommended them and installed them) and it wouldn't make any power and had poor driveability.
Swapped in a new set of stock Plugs and Whala!
Everything came back to normal.
Ted.
Old 08-12-2010, 11:14 AM   #11
quinthawk
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1
Ted,
What plugs do you recommend for a L99 with a maggie 3.6" pulley, headers and cai.
I am running ngk tr6.
thanks
quinthawk is offline   Reply With Quote
Old 08-12-2010, 11:23 AM   #12
Outlaw77
Outlaw77's Avatar
Drives: 2018 Charger SRT 392 F8 Green
I've always used Bosch plugs in other cars. They are a great oem manufacturer of long lasting plugs.
Outlaw77 is offline   Reply With Quote
Old 08-12-2010, 11:25 AM   #13
JS
JS's Avatar
Wanna guess which plugs are in this car
Its nothing more than a 3000HP OUTLAW 10.5 Car that WE TUNE
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 08-12-2010, 11:26 AM   #14
JS
JS's Avatar
We run NGK OR AUTOLITE and its one of those SUPPOSED JUNKY COPPER PLUGS
SOLD
2010 Camaro 1SS/A6
12.59@111.31
E3 Spark Plugs for SS jmlozano7 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 06-11-2016 09:22 PM
What type and heat range are the stock LS3 spark plugs? topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 06-29-2010 11:45 AM
Spark Plugs? 1985HOL69305 4th Generation Camaros 4 04-05-2010 01:08 PM
Need help with changing spark plugs. HeavyD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 11-24-2009 03:13 PM
