Old 03-05-2011, 09:41 PM   #1
TripleB
SoCal Mayhem
TripleB's Avatar
window indexing issue
i'm not sure if this is the right forum for this or not, i thought maybe the mechanical section, but that seems to be more for oil changes and such.
i think i have an issue with my window indexing and wanted to know if anyone else had the same issue or how i could go about fixing it or correcting it.
my driver side window indexing only goes down like half an inch or so. my passenger side used to be the same. now the passenger side seems to go down like an inch and a half or maybe more. i checked with my buddy and his camaro and also on my dad's camaro and they don't have this issue. on both of their cars, both windows only go down about half an inch. i tried to roll down the window all the way and then back up to have it "relearn" where the open/close points are (had to do this when i got the car and i would get the "roll window down/up" message on the DIC).
anyone else have this issue?
i tried to get video of each window but it was kind of hard with my phone. i think you can still see what's going on in them though. if they don't work just yet, give youtube some time, i just uploaded them like 10 min ago.
driver side:
passenger side:
Old 03-05-2011, 09:46 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
is the computer informing you to raise/lower window(s)? hold window 5sec up/5 sec down..worked for me..
Old 03-05-2011, 09:47 PM   #3
TripleB
SoCal Mayhem
TripleB's Avatar
no, it's not informing me to do that. it did the during the first day i had the car a few times. ever since then, it hasn't said to raise/lower it. i just thought that might help it so it would know what closed was and not index so much when opening the door.
Old 03-05-2011, 09:56 PM   #4
p3jason
Allergic to stupid.
p3jason's Avatar
Drives: 2015 ZL1 #957 M6 AGM & 1990 Z24
Send a message via Yahoo to p3jason
What does it matter how much it opens as long as it closes all the way? My passenger window indexes about twice as far as the driver window. It closes all the way when closed so no problem.
p3jason is offline   Reply With Quote
Old 03-05-2011, 10:07 PM   #5
TripleB
SoCal Mayhem
TripleB's Avatar
i was just curious if it was an issue or not. it used to NOT index so far, now it does. i wondered why and if anyone else had this going on. thanks for your input though.
Old 03-20-2011, 10:23 AM   #6
TripleB
SoCal Mayhem
TripleB's Avatar
Forgot to mention before that I was worried it could be indicating an issue with the window regulator. Those are expensive to fix, should still be under warranty, but you never know when it's gonna go out.
And it looks like it is an issue, TSB link:
http://www.camaro5.com/forums/attach...2&d=1277922156
Old 03-20-2011, 10:43 AM   #7
ron10
Drives: 2010 2SS IOM L99
i would take it to your dealer.they probably won't do anything about it,but it will at least get the issue on record that there is a problem.
Old 03-20-2011, 10:48 AM   #8
Romeloc
Romeloc's Avatar
Drives: 2010 Black 2SS RS A6 Inferno
mines has been doing it lately too.J ust started a few months ago.
[SIGPIC][/SIGPIC]2010 Camaro Black 2SS/RS A6 Inferno Interior Polished Rims, Sunroof
Born 11/19/09
mods:
20% tints
Borla Atak cat-bak
Roto-Fab intake
amber footwell, dome, and trunk lighting(AAC)
Decepticon Gas door
Led Taillights (technostalgia)
Romeloc is offline   Reply With Quote
Old 03-20-2011, 11:27 AM   #9
boltmark
Drives: 2010 2 SS/RS IOM Camaro
In the manual it tells you how to reprogram this. I had to do it and now it's fine.
boltmark is offline   Reply With Quote
Old 03-20-2011, 12:19 PM   #10
TripleB
SoCal Mayhem
TripleB's Avatar
I've tried that a few times and it doesn't work.
GM Window Sticker Repo In Canada Bumlbee Canada 8 01-10-2011 12:14 PM
Busted Door Window (due to sun / heat & high humidity) 67ponycar Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 28 07-13-2010 03:09 PM
Window Indexing Issue Sirscratch Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 06-28-2010 11:32 AM
Window Indexing issue getting worse in cold weather. Rogue Leader Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 02-16-2010 12:53 AM
LOOK right rear side window problem kga10734 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 01-03-2010 04:55 PM
