Old 10-13-2009, 02:24 PM   #1
Pope Designs
Drives: 2013 ZL1 Rally Yellow
Trying to get 500 RWHP without a Super Charger
So what else can I do? Below are my mods so far.
LMR CAI
Custom Tune
SW Headers
Custom Grind CAM
Cat & Res Delete W/ 40's Flow Masters
Right now I am at 443 RWHP. I need to find 57 more!
Thanks for any suggestions.
Bryan
Pope Designs is offline   Reply With Quote
Old 10-13-2009, 02:28 PM   #2
toehead93
Drives: 2014 2SS/1LE
A bigger cam. Check out the Corvette forums, there are a lot of cam only LS3s with over 500hp. I think I saw a set of heas add just 15hp so you might want to look into a fast lsxr intake and TB.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 10-13-2009, 02:29 PM   #3
rodimus prime
Drives: Cargo van.
Some ported heads and a cam. To squeek out a few more get a pulley and port the intake and throttle body.
rodimus prime is offline   Reply With Quote
Old 10-13-2009, 02:30 PM   #4
Pope Designs
My Cam is already pretty aggressive.
Bryan
Old 10-13-2009, 02:39 PM   #5
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
ported manifold, throttle body, ported and polished heads, N20
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 10-13-2009, 02:58 PM   #6
_GTO_
_GTO_'s Avatar
Drives: holden commodore
taylor 10.4mm Wires, underdrive pulley, NGK spark plugs, 160* Thermostat, Ported TB,intake manifold and heads , you'll get even more than 500RWHP.
BTW what is your cam spec? It seems tiny .
_GTO_ is offline   Reply With Quote
Old 10-13-2009, 03:13 PM   #7
Pope Designs
22X - 23X 115+X 6XX-6XX
Old 10-13-2009, 03:14 PM   #8
Pope Designs
One thing is I only have 333 miles on the car. I have been told over and over to drive the crap out of it and I will see 25 more horses?
Bryan
Old 10-13-2009, 03:25 PM   #9
2Tightwads
Banned
Drives: 2002 LS1 swapped into a 1994 Z
500HP mark - They did it with cam/ported stock LS3 heads months ago in GM High Tech Performance. This should be a pretty simple ta'do considering the amount of power that comes stock from the factory. I believe it was a rowdy sized cam for a 5th Gen. owner, but nothing new to the 4th Gen. Camaro/Firebird world.
2Tightwads is offline   Reply With Quote
Old 10-13-2009, 04:32 PM   #10
DetroitMuscle2010
DetroitMuscle2010's Avatar
if your willing to step up the valve springs we can spec you out a cam that may get you alot closer to your goal, that's not what we would consider a aggressive cam
DetroitMuscle2010 is offline   Reply With Quote
Old 10-13-2009, 04:47 PM   #11
Jason@RPM-Motorsports
Jason@RPM-Motorsports's Avatar
Drives: 98 WS6
I will be that if you make over 500 rwhp with a LS3 "Cam Only" fly cutting is required.
Jason@RPM-Motorsports is offline   Reply With Quote
Old 10-13-2009, 04:54 PM   #12
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
418 CI motor
Old 10-13-2009, 05:23 PM   #13
matt55
matt55's Avatar
Drives: CTS-V
Didnt that car have a baseline of +400 RWHP to start with (not a dynojet dyno) ?
So with bolts on and a cam 100 RWHP gain ...
Hold on found it
base line 406 WHP (HIGH reading dyno?)
Cam + boltons 482 WHP
Heads+cam+boltons 518 WHP
So 112 WHP from all that , Bryan all ready gained 89 WHP cam only .
link
http://www.gmhightechperformance.com.../photo_27.html
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 10-13-2009, 05:34 PM   #14
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Super Charger for the Camaro??? Triton2110 Forced Induction - V8 5 05-06-2011 10:20 AM
What do you think about this Super Charger? profunctional Forced Induction - V8 5 08-30-2009 12:14 AM
Say I want 500 RWHP Wrath Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 05-30-2009 04:57 PM
Super charger.. Vizon General Automotive + Other Cars Discussion 16 05-18-2009 02:24 PM
SUPER CHARGER? Triton2110 Forced Induction - V8 17 03-31-2009 06:04 PM
