Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
Rough Idle
Ok I am using 91 Octane as that's the most prevalent here in Phx, but it still idles rough... did the fuse pull and that didn't help.
Let me specify rough... NOT a "motor's gonna stall" kinda rough, but the car will vibrate and then smooth out then vibrate and smooth out...just don't seem run smooth like a car with 2k on it should IMO... Something unusual or am i still just paranoid?? Thx guys!
2G1FS1EWXD9163847 |
#2 | |
![]() Drives: 2010 CGM 2SS/RS 6M Join Date: Feb 2010
![]() As long as it isn't having problems with stalling you should be OK. Mine does it too. |
Haha ok i Figured, but wanted to be sure. Thx!
2G1FS1EWXD9163847 |
![]() Drives: Camaro 2015 RS CRM Join Date: Apr 2009
I use 93 octane and I do not have that issue. A little vibration is normal, but what you're describing sounds odd. Assuming the the car is not ice cold and assuming that you don't have any engine/exhaust mods, I would suggest that you take it to your dealer.
IOM 2SS/RS manual
1100 - 4/7/09 3000 - 5/27/09 6000 - 7/17/09 See my Thread in New York Metro Area. http://www.camaro5.com/forums/showthread.php?t=33878 |
Its worse when it's cold naturally, but when it warms up it still does the same thing, you feel a little bump left and right as it's idling... It just has an intake and muffler delete..
2G1FS1EWXD9163847 |
#6 |
Check your CAI bolts and air sensor connection to make sure that they are tight.
IOM 2SS/RS manual
#7 | |
2G1FS1EWXD9163847 |
#8 |
![]() Drives: 2014 Camaro 2SS RS LS3, BRM, NPP Join Date: Apr 2010
That is one of the benefits of having a performance V8 with a nice cam. I love the rock and roll of a good V8 at idle/low RPM.
If you want a silky smooth car get a Cadillac.
Experience is the best teacher but the tuition is very high.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
mine does this a little
#10 |
Emerald Coast Camaros
Drives: 2010 Supercharged RJT SS! Join Date: Jun 2009
It's a little sweet song I like to call "Lope"
![]() It's kinda fun to watch mine at a stoplight. The needle moves up and down between 500-800 RPM's. It's nice. Just wait till(if) you put a more aggressive cam in it. Oh the sound of that. ![]()
2010 Camaro SS LS3 Supercharged RJT!
Magnuson TVS 2300 Supercharger, ARH 1 7/8 LT Headers with 3" X-Pipe, Borla S-Type Axle-Back, DMH Low Profile Exhaust Cut-Outs, MTI Racing CAI, Stage 2 Camshaft(227/239 .614/.624) with new springs, Katech C5R Z Timing Chain, LS7 Bowtie Damper, MTI Hot Spark Plug Wires, MTI Racing Lowering Springs and Swaybars, Aluminum Oil Catch Can, 160 Degree Thermostat, MTI Tune. 554RWHP 528RWTQ Built By: MTI Racing Dyno Sheet here |
#11 |
![]() Drives: Yellow 2SS, 6 speed manual Join Date: Jan 2010
378 cubic inches
.550/.522" lift camshaft (with tame 204/211 degree and 117.5 LSA) 430+ hp Considering those numbers these engines idle quite well. A 377 or 383 stroker with those specs wouldn't idle quite as smoothly as the LS3. |
#12 |
Surely thou jivest...
Normal....nature of the beast.
#13 |
Senior Member
Drives: 2010 Camaro / IOM / SS / RS Join Date: Apr 2009
LS3....Normal.....
| LS3 rough idle | HeaterMan | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 14 | 05-16-2010 01:50 PM |
| Just got the 2SS ... Scratch ... Rough idle (vibrates unusually) | advanceNconquer | 5th Gen Camaro SS LS LT General Discussions | 52 | 03-27-2010 01:10 AM |
| 2010 Camaro 2SS/RS M6 Rough idle problem | 2010Inferno | 5th Gen Camaro SS LS LT General Discussions | 10 | 02-14-2010 08:36 PM |
| rough idle | ssmike | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 07-15-2009 06:03 PM |
| rough idle and backfires, why? please help | chevyryda | 4th Generation Camaros | 6 | 06-07-2009 09:00 PM |
