Old 12-13-2010, 08:59 PM   #1
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2013 1LE
Trouble putting gear into Reverse!
So I have a manual, and I have never had trouble putting the car into any gears until tonight. I drove to my gf's house to go out to dinnner with her and her family, but when I wanted to reverse out of the driveway I just couldn't get the car into that gear. I pushed real hard to the right to get it going and as I was doing that I heard grinding and then finally it when up and into reverse.
Now I am worried. When I got back to her house I was fiddling with it again and each time it just didn't want to go into reverse and all I heard was grinding noises. Every other gear 1st-6th works just fine its only reverse giving me issues
What could be the problem?
I am taking the car to the dealership bright and early in the morning.
Thanks C5!
Black 2013 1LE - Bolt ons - Heads - Cam- Suspension - Built by Jrod - Sorian Tuned
shadow09 is offline   Reply With Quote
Old 12-14-2010, 12:28 AM   #2
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
It's happened a few times with mine. Never the grinding part though. just put it in neutral and roll the car back a foot or two and try again? Or you can force it.
I didn't think anything of it more than a minor annoyance because I was able to get it to work fine the few times it happened to me.
Please let me know if the dealer finds anything.
Old 12-14-2010, 01:54 AM   #3
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
You didn't to recently install a skip shift eliminator did you?
It's pretty common to accidentally plug it into the reverse lock-out by accident.
Sterling is offline   Reply With Quote
Old 12-14-2010, 02:02 AM   #4
shadow09
H-Town Camaro Club
shadow09's Avatar
Drives: 2013 1LE
yeah I recently installed a skip shift eliminator. but I don't think I plugged it into the wrong one. I looked up install pics and made sure I plugged it into the correct wire.
http://www.camaro5.com/forums/showth...inator+install
I'll jack the car up in the morning and change the skip shift eliminator into a different plug
Old 12-14-2010, 05:38 AM   #5
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I don't have the CAGS installed.
Old 12-14-2010, 07:24 AM   #6
ssmike
BL1ZZRD
ssmike's Avatar
When I installed my skip shift eliminator I put it on the wrong plug and I had the same symptoms as you. It should be in the center drivers side up toward the top of the tranny. If you installed it into a lpug toward the rear of the tranny that's the wrong one!
Old 12-28-2010, 10:21 PM   #7
LEONUM7
Drives: 2010 Camaro SS
I’m also having issues w/ my 2010 Camaro. When reversing I hear a grinding sound and then like a winding up sound. I hear a grind, but I don’t actually feel it on the shifter like normally you would when missing a gear.
LEONUM7 is offline   Reply With Quote
Can not shift into reverse gear. HELP! Bryan 5th Gen Camaro SS LS LT General Discussions 20 11-04-2021 07:17 PM
2011 Reverse Indicator Stuck Kid Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 08-09-2010 03:16 PM
Why Top Gear is the best show in the world rez333 General Automotive + Other Cars Discussion 13 07-15-2010 02:38 AM
Hitting reverse by accident? Blue Angel 5th Gen Camaro SS LS LT General Discussions 29 02-16-2010 03:34 PM
