Old 03-02-2010, 10:20 PM   #1
captains1
Drives: 2010 black ss2
correct tire pressure?
Hey everybody,new to this forum and just got my camaro ss2 Friday and am loving her!!
Sorry if this has been asked before,but I am wondering correct tire pressure for these stock Pirelli's? I drove about ten minutes tonight,and it went from 32 on back and 34 on front tires to only 33 on one rear and 34 on the other,and to 36 on both front tires? Just curious if this seems low to someone who knows what it should be,thanks for your help!
captains1 is offline   Reply With Quote
Old 03-02-2010, 10:30 PM   #2
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
The inflation pressure is printed on the side of the tire. And can be found in the owners manual as well.
anthonybyram is offline   Reply With Quote
Old 03-02-2010, 10:37 PM   #3
Dano
Dano's Avatar
Drives: 2022 Camaro 2SS 1LE M6
According to the tires and the owners manual they should be set to 36 psi. However when you drive and the heat builds up in the tires the pressure will increase.
2022 Shadow Gray 2SS/1LE, M6, PDR
Dano is offline   Reply With Quote
Old 03-07-2010, 08:55 AM   #5
captains1
ok-thanks guys!
Old 03-07-2010, 11:58 AM   #6
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
On the SS cars the max pressure on the Pireli's is 50 lbs. I am running mine at 40 to 41 cold which will give better tire longevity. They pick up about 2-3 psi after driving awhile. Also, if the sun is low it will heat up the two tires exposed directly to the suns heat by another pound or two. Great system.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 03-08-2010, 12:05 PM   #7
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Maximum inflation pressure is on the side of the tire; not what you want to inflate the tire to; use the Owner's manual; 36 PSI cold.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
Old 03-08-2010, 12:10 PM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's also printed on the driver side door.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-10-2014, 10:27 AM   #9
jwil0587
Drives: 2011 1LT RS
Just wanted to throw my 2cents in. I worked in a tire repair/sales shop for 2 years while in college. NEVER run the pressure stamped on the tire the number stamped on is "Max" pressure. Always look for vehicle specific numbers and in our case its 36psi cold like stated above.
jwil0587 is offline   Reply With Quote
Old 03-10-2014, 05:03 PM   #10
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
The tire pressure on the sidewall is the MAX inflation pressure. Use the owners manual or the door placard on the inside door jam.
36 PSI!
Rudy@Tirerack is offline   Reply With Quote
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Best tire pressure for fuel economy = 38? Booneabal Wheels and Tires Talk Sponsored by The Tire Rack 13 02-23-2010 02:26 PM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 11:58 PM
Help with tire pressure monitor bigkahuna4444 Wheels and Tires Talk Sponsored by The Tire Rack 0 10-29-2009 01:16 PM
Tire Pressure Problems Matster Canada 14 10-03-2009 07:11 AM
