Old 01-13-2010, 01:34 PM   #1
The Stig
knows 2 facts about ducks
The Stig's Avatar
List of Camaro5 DIYs
I've been slowly compiling a quick guide list for all of you to view and use similar to the helpful links thread I started in the 4th gen section.
Some guides have not been selected, mainly due to lack of pics or detailed examples. Because like the old addage goes "A picture is worth a thousand words". I will be sending pm's to members who have already added a guide for more detail/pictures in certain areas because while some members might know what a part is or where its located, other members (and guests) reading the thread might not know exactly where/what someone is talking about. And in an effort to assist our fellow members (and to add to our database here), I want to ensure that we have the most up-to-date and precise information. This is still in work so bear with me as things get added.
Also, I will add the disclaimer that these articles are submitted by auto enthusiasts like yourself, and therefore Camaro5.com cannot be held responsible for any damage done to your personal property, or any injuries you sustain. Some of the articles may describe work that may void your car's warranty (if you still have one), and once again, Camaro5.com can not be held responsible for such things. By viewing the articles posted here you agree not to hold Camaro5.com liable for any damage, accidents, or any other harm to any of your possessions that may occur. Thank you for understanding.
General DIYs
Bolt-Ons | Intakes | Exhaust
DIY: Radiator Replacement
QTP Cutout Installation
Noweeds Diverter Installation
GTO Clutch Reservoir Install
Proven Wicked Rear Tow hook Installation
DIY: Coding your GM locking gas cap
Tools and Garage Stuffs
Duct tape | Rednecks | Bad ideas
How to make your own bushing removal tool
DIY: Removing Gorilla Wheel Locks without the Key
ZL1 Engine, Exhaust, and Bolt-Ons
DIY: MILD TO WILD for ZL1 or any camaro with dual mode exhaust
DIY: Roto-Fab Cold Air Intake Installation Video
DIY/How-to: How/What fuse to pull for NPP (Dual mode exhaust)
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons
The Moreno Brothers: Project Cleaning the Clutter in Our Engine Bay
DIY: Replacing Fuel Lines and Fittings
LS3 Engine Specifications
Fastener Tightening Specifications (6.2L LS3).pdf
DIY: How to Hide Your Evap Solenoid
DIY: LS3 Camshaft Install
DIY: Install headers on 2010 Camaro SS
DIY: High Flow Catalytic Converters Installation
DIY: Shorty Headers 2011 LS3 V8
DIY: ADM Scoop & Apex Washer Tank Installed with a CAI intake
DIY: 2010+ Camaro SS Fuel Line Retrofit
DIY: 2010-11 SS Heater Hose 2012 Update
DIY: Replacing the Starter (LS3 and/or L99)
Engine Mounts Installation Tutorial
Valve Lifter Replacement (With AFM).pdf
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
DIY: V6 Mace ported IM/25mm spacer/porting heads install
DIY: 1LE Oil Separator install on a V6
DIY: Add a Clean-side PCV Connection to the V6 Vararam
DIY: CAI Intake, Scoop, & Washer Bottle w/ CUSTOM BRACKET & MRTv2's Install
Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
For all LFX related parts
DIY: 1LE Clean Side Separator on LFX
Forced Induction - V8
V8 Supercharger, turbo, nitrous discussions
Forced Induction - V6
V6 Supercharger, turbo, nitrous discussions
Tuning / Diagnostics -- engine and transmission
Tune and diagnostics for engines and auto/manual transmissions
How to remove the PCM on a 2010+ Chevy Camaro
JRE SCT X3 Custom Tune Instructions (Revision 6)
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
DIY: Disable 2013 HSA (Hill Start Assist)
DIY: Hurst Short Throw Shifter Install - Pix and Video
DIY: Short throw shifter by modifying stock shifter *WARNING* This is long
DIY: 4L80-e complete swap guide. (With part #s)
DIY: Complete Rear bushing and 3.91 gear swap
Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Discussions on mechanical maintenance and servicing of your Camaro
How to jack up a new camaro with a floor jack, and jack stand locations
The "Catch Can" Explained!
DIY: V8 Oil change
DIY: V6 Oil Change
DIY: PCV Catch Can Installation
DIY: LFX Intake Manifold / Valve Cleaning
DIY: Seafoam a Camaro LLT V6
DIY: Changing Rear Differential Fluid
DIY: How to change Your Cabin Air Filter
Suspension / Brakes / Chassis
All suspension, brakes and chassis discussions.
DIY: Trailing Arm Install
DIY: Trailing arms outer bushing removal
DIY: Trailing Arm Install without a bushing tool
DIY: Lowering Springs Installation (more pics)
DIY: Install your own Drop Springs (C5 Camaro)
How To: Adding the Factory Strut Brace to your 2010 Camaro
DIY: change Brake Pads/ rotors (Brembos)
DIY: V6 Changing Rotors & Brakes
DIY: Brake line replacement & Brake bleed; Step by step
SHURE-FIRE METHOD TO CURE BRAKE SQUEAL
DIY: Make your own cradle bushing inserts
DIY: Rear Differential Mounts
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
All audio, video, bluetooth, nav, radar, and electronics discussions.
Headunit/Speaker Related
DIY: ******** 5 Channel Total System Enhancement Package Install
DIY: Installing front speakers LOTS OF PICS
DIY LOC input harness for rear speakers (No cutting, no splicing)
DIY: Speaker Install
DIY: How to Stop Rear Speaker Rattle
DIY: PDIM + USB Port installation
DIY: Upgrade to outside heated mirrors
DIY: Raptor Shift Light Install
DIY: iPad Dash Mount without center speaker
How To: Enable your factory radio to add Bluetooth or hookup radar detectors etc
DIY: hard wire radar detector on dash
DIY: side camera
DIY: Changing LEDs in Speed/Tach Gauge
How to: running wires into/through the door
DIY: Installing steering wheel audio and phone controls on Camaro
How to install Ofer's backup camera retrofit
DIY: Aftermarket (non-GM) Back Up Camera
DIY: constant 12v for cigarette lighter socket
DIY: Installing/Retrofitting HUD into your camaro
DIY: Constant Hot Power Outlet (Add A Circuit)
DIY: Adding Power to the Passenger Seat
DIY: ADM boost gauge install
DIY: Changing the LEDs in the Radio/Headunit
DIY: Curb Alert Pro Install
DIY: Cruise Cancel Button to Control Line Lock
LS7CamaroECMpinout.pdf
Cosmetics and Lighting Modification Discussions
External and Internal cosmetics modifications.
Painting / Plasti-Dipping
DIY: Engine Cover Painting
DIY: How to Plastidip your Camaro Rims
DIY: Paint Your Own Bowties
DIY: Paint your interior ABL Trim Panels
Exterior
2014 Heat extractor on a 2010-2013 hood
DIY: SSX bowtie (aka the Z/28 flowtie)
DIY: Installing a Color Matched XM antenna
DIY: Make your own front Mud Flaps
DIY: Pinstripe the outer edge of your Wheels
DIY: Remove outside door handle
DIY: No Drill GM Dovetail Spoiler (3M)
DIY: Fog Light Bezel Removal
DIY: 3D carbon fender vents installed
DIY: Heritage Grille Install - (Remove and Reinstall Front Bumper/Fascia)
DIY: Installing ORACLE Concept LED Side Mirrors from AAC
How to: OEM Ground Effects Install
DIY: Front Fascia Remove/Install
DIY: Video Rear fascia Removal
DIY: Stock Side Skirts Removal and Installation of ZL1 side skirts
DIY: Stock Rear Diffuser Removal (non-GFX)
DIY: ZL1 Diffuser Install
Front License Plate (No drill method)
DIY: Quarter Panel Gill Inserts
Exterior Lighting
DIY: NightOwl DRL Halos
DIY: on adding outside door handle lighting
DIY: "Scare free" Afterburners
DIY: LED STRIP SIDEMARKERS
DIY: Sequential Taillights for approx $20
DIY: Lighted Engine Cover w/ "Colorshift" LEDs
DIY: Non RS headlight to RS headlight conversion + Front Bumper Removal
DIY: Install LED SWITCHBACK TURN SIGNALS White DRL and Amber Blinker in one! For RS
DIY: Installing AAC's High Power Reverse Lights
How to: Install HID Fog Lights LS/LT
DIY: LED Night Rider Scanner V2.0 install pics
DIY: Color Changing Halos for Under $20
Interior
DIY: Interior dash trim and door panel / door trim removal instructions
DIY: Door Panel Removal and Reinstall
DIY: How to Remove A/C Vent Bezels On a Camaro
DIY: Removing the trim bezel on a 2012 steering wheel
DIY: How to Change the Faces and Gauges to your Speedo/Tach/Aux Gauge Set
DIY: DSV Parking Brake Leather Boot Install
DIY: Manual leather boot install on auto shifter
DIY: Center Console Arm Rest Install
DIY: Retrofit 2012 camaro dash into a 2010 car
DIY: Changing The Steering Wheel
DIY : M6 shift knob removal on a 2013
DIY: Installing 2013 Door Pulls into a 2010 or 2011 Camaro
Interior Lighting
DIY: ABL Lighting of the HOMELINK BUTTONS
DIY: How to mount accessory switches in the cup holder area
DIY: LED Footwell Lighting with Dimmer Switch
How to: wire rear seat footwell lighting
How to: Wire Footwell Lighting
DIY: Door light projector "CAMARO"
How to: install an adapter ZL1 harness
DIY: Footwell Lighting Install - Dome/Toggle Switch
DIY: Trunklighting with an LED strip **EASY!!**
DIY: Make your dome light any color (PDF file)
Ambient Lighting
DIY: Dash ABL Install Version 1
DIY: Camaro Dash ABL Install - GM Parts House
DIY: ABL using EL wire, and 3/16" tube
DIY: Changing the color of your ambient lighting (ABL)
Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection
Anything related to keeping your Camaro clean and in good cosmetic condition.
Washing and Detailing for Newbies
Junkman's "How To Care for Your Vinyl Stripes"
Junkman's, The Mother of All "How to Fix Your Paint for Novices" Thread!
A Novice + Rotary Polisher = Step Inside...
HOW TO VIDEO: Caring for Factory Camaro Stripes
How to: Properly Remove Dust without Scratching Up Your Paint - The Videos
Adam's Quick Reference Detail Guide PDF
HOW TO: Detail Your Engine Bay
HOW TO: Clean Your Wash Pads
DIY: Video - GT Yellow Fog Light Protection Kit
Miscellaneous DIYs
DIY: Fix Your Broken Seat Warmer
DIY: Assembling and Disassembling of the Key Fob
DIY: Adding YOUR car to YOUR Tom Tom
Plast-Dip Application Tips
Click to view my build thread
Old 12-21-2012, 07:12 PM   #2
The Stig
The Stig's Avatar
Creating/Organizing a list of all of the DIYs on Camaro5. If you know of a good/detailed DIY for a topic that has not been covered please post the link.
- The Stig
Old 02-18-2013, 07:23 AM   #3
332
Drives: 2SS
Torque Specifications for the LS3 engine link doesn`t work anymore. A little help?
332 is offline   Reply With Quote
Old 03-18-2013, 09:40 AM   #4
The Stig
The Stig's Avatar
Just checked it, works for me
Old 04-01-2013, 02:26 PM   #5
The Stig
The Stig's Avatar
Redid the torque specs PDF. Should work now.
Old 04-13-2013, 10:35 AM   #6
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I know there is a DIY for the changing pads/rotors for the brembo but here is one for the v6:
http://www.camaro5.com/forums/showthread.php?t=288980
kjkjr27 is offline   Reply With Quote
Old 04-15-2013, 01:53 PM   #7
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Here's a great DIY on cleaning the LFX intake: http://www.camaro5.com/forums/showthread.php?t=288997
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 04-17-2013, 08:18 AM   #8
The Stig
The Stig's Avatar
Added
Old 04-17-2013, 08:33 AM   #9
AKA-22
AKA-22's Avatar
Drives: ELLE-1
sub
AKA-22 is offline   Reply With Quote
Old 04-20-2013, 08:29 AM   #10
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
Old 04-26-2013, 06:43 AM   #11
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
GREAT List............subscribed, and will read them all over the next couple weeks.
Thank - you
Old 05-04-2013, 12:35 PM   #12
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Well done Stig. This section was suffering from serious neglect last time I was in here. Good to see things are back on track now.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-07-2013, 10:41 AM   #13
The Stig
The Stig's Avatar
Bump
Please post links to any DIY's that you think should be added to the list.
Old 05-07-2013, 12:22 PM   #14
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
If like a DIY for adding an amp and sub to a non BA camaro
brandotron is offline   Reply With Quote
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 10:08 AM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
DIY Vinyl Bowtie Black Outs srevoal Camaro DIY & HOW-TO instructions & discussions 3 12-11-2009 06:13 PM
DIY lowering springs install?? BOULI306 Camaro DIY & HOW-TO instructions & discussions 3 12-08-2009 06:38 PM
Should you DIY headers install... or should you pay to have it done Jakefeb3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 11-10-2009 07:27 AM
